Slic3r configuration files
Hi Repetier
I am using appimage installation on Ubuntu 14LTS an it sems ok with slic3r, but if i want custumize slicer parmeters what i have to do ?
If I click on configuration button in log windws i see this
18:45:29.768 : <Slic3r> LD_LIBRARY_PATH = /tmp/.mount_RepetiruS11d/slic3rImage/usr/lib:/tmp/.mount_RepetiruS11d/slic3rImage/usr/lib/local-lib/lib/perl5/x86_64-linux-thread-multi/auto/OpenGL
18:45:30.410 : <Slic3r> Can't load '/tmp/.mount_RepetiruS11d/slic3rImage/usr/lib/local-lib/lib/perl5/x86_64-linux-thread-multi/auto/Wx/Wx.so' for module Wx: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /tmp/.mount_RepetiruS11d/slic3rImage/usr/lib/libwx_gtk2u_adv-3.0.so.0) at DynaLoader.pm line 193.
18:45:30.410 : <Slic3r> at /tmp/.mount_RepetiruS11d/slic3rImage/usr/lib/local-lib/lib/perl5/Slic3r/GUI.pm line 7.
18:45:30.411 : <Slic3r> Compilation failed in require at /tmp/.mount_RepetiruS11d/slic3rImage/usr/lib/local-lib/lib/perl5/Slic3r/GUI.pm line 7.
18:45:30.411 : <Slic3r> BEGIN failed--compilation aborted at /tmp/.mount_RepetiruS11d/slic3rImage/usr/lib/local-lib/lib/perl5/Slic3r/GUI.pm line 7.
18:45:30.411 : <Slic3r> Compilation failed in require at (eval 84) line 1.
Thanks Alberto
configure with Manger the config directory and the executable directory all seems ok
Alberto
Alternatively you can compile slic3r yourself and configure host to use your compiled version. We use the official binary release of slic3r so using that will not help here, so compiling is the only solution to get it running on older devices.
