Printer not moving after starting a job, but gcode is running in console
Hi!
Just an amateur printer trying to hook up repetier server to free up my laptop from dedicated printing sessions.. i used repetier host in the past and also played with octoprint..
I can control my printer manually, but when I start a job the printer just sits there. In the console if i turn on commands and ack i can see the following gcode running:
13:28:51.624: ok (2)
13:28:51.624: N1167 G1 Z30.000 F120
13:28:51.624: N1168 G92 E0.0000
13:28:51.624: N1169 G1 F120
13:28:51.632: ok (3)
Is something wrong with the communication of the server to the printer??
Thanks for any and all help in advance!
-Stephen
-Stephen
13:37:38.751: ok T:195.5 /195.0 B:50.3 /50.0 @:31 B@:18 (2)
that is strange - why should server need 340 byte to send a command. No firmware has such a big buffer and no gcode should need it. Only comments could be that long but do not get send. Any idea what command it want's to send here?
