Z probe not working
I'm currently putting together a large format cartesian printer 900x400x900 and I'm having trouble getting z probing working.
I have x & y min and z max optical endstops, the z probe is a spring bike spoke which also uses an optical endstop to sense.
I got quite confused while trying to troubleshoot this issue so my pins.h are all messed about, currently set up as follows:
x min, 14
y min, 15
z probe, 18
z max, 19
All borked I know but the cables are physically in the correponsing location on my ramps 1.4:
3 2 14 15 18 19
x x y y z z
-x -y zp +z
So the issue is, the Z probe does not respond to actuation, I know every sensor is working as well as the board as changing the pins.h around always results in working endstops but a non responsive probe, e.g. set to:
x min, 14
y min, 15
z probe, 19
z max, 18
The probe opto when triggered will change the state of z_max in Repetier Host but the z max opto when triggered will not result in any change for z_probe.
Reading through posts I've seen some people sugest changing
#define EEPROM_MODE 1
to 2 but I have no idea what that does and changing it had no effect on the printer's behaviour.
Here is the Z-probe section from my configuration.h:
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PIN ORIG_X_MIN_PIN // #define Z_PROBE_PIN ORIG_X_MAX_PIN
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1 //was 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
the comments are my own notes on changes I have made.
x min, 14
y min, 15
z probe, 18
z max, 19
3 2 14 15 18 19
x x y y z z
-x -y zp +z
x min, 14
y min, 15
z probe, 19
z max, 18
seems strange that you have Z probe connected to the X min pin when you allso have a X min endstop
The travel in the Z axis is about 900mm, when G30 sent, the bed moves up towards the probe, at about 400mm, the motors stop for a moment, the steppers go silent for a second, then it continues it's ascent. After triggering the probe, the bed descends to about the same height it paused, and reports a z-length of 600ish.
However the host reports a Z-position of 900 (home) once the process is finished.
I've been using this guide:
https://www.repetier.com/documentation/repetier-firmware/z-probing/
but it seems there is a lot I am missing, I would like to use the BED_LEVELING_METHOD 1 as the bed is likely to warp and move a lot between prints due to its size. I also need to send the effector to a specific point on the bed to retract the probe. I can't see how any of this can be done with the printer thinking Z600 is actually Z900.
