no connect with repetier server
Hi All
when I load repetier and connect to the server i get a green connect but printer is dead and the manual panel shows not connected.
Using Win 10 hope someone can point me in the right direction.
The last line in the log window is as follows
At REPETIERSERVERCONNECTOR,SERVER CONNECTOR,WSRECEIVE2 (OBJECT SENDER,MESSAGE EVENTARGS E)
IT SEEMS THAT WHEN I LOAD THE REPETIER HOST WITH THE SERVER RUNNING AND GO TO THE SERVER CONNECT
BAR IT CONNECTS BY THE HOST CONNECT ICON BUT IF I SWITCH TO MANUAL IT SHOWS THE PRINTER IS DISCONNECTED.
THANKS FOR YOUR HELP
jOHN
