Eleduino 7-inch usb touch display compatibility
Hi guys
I'm currently looking to purchase Repetier-Server and run it on the Pi 2 (since I currently run the free version for Windows with much success)
I'd like to know if this display is supported by your current build of Repetier-Server?
Eleduino Raspberry Pi 7 Inch 1024x600
If not, would I be able to run Raspbian (which does support the display+touch through USB) and install repetier server as a deb package for arm?
Best,
Seven
Best,
Seven
The image is just the stock raspbian stripped down and preconfigured. But depending on display/touchscreen you might need to add the drivers/settings the screen vendor offers to see it.
I'll let you know if it works!
