g code for heat bed and fan not generated when using right extruder only
I am having to manually control heat bed and fan when I use right extruder only. I have a Davinci 2.0.
#2 ext. is chosen and I have set the bed temp to 60 c, fan control to auto in the filament settings but Slic3r is not generating these when sliced. Please advise if I am missing something. Thanks in advance.
I really appreciate your help.
Thanks again for all of the hard work all of you are doing to make it easier for people like me.. ........
Just see that forum software has reduced my answer to first section :-(
Check slic3r_settings.ini in work directory - there it should write the values comma separated. For that reason it is important to not use a comma as decimal value like done in some countries. That might cause exactly your problem.
It's curious that Cura will generate the code for the right extruder only, but when the print starts it shuts off the extruder but goes through the motions of printing, although its off center. I know this is another topic and I will start a new post someday.
Thank you again.
I created a filament setting called "no extrude", set the extruder temp to 0 and the bed settings to 65. I assigned it to the LEFT extruder and that worked for the the bed..... Still trying to figure out the fan. Will post back when I do
