All files and data is located in the /var/lib/Repetier-Server folder. So if you have enough free disk space you could simply create a tar file from this cd /var/lib sudo tar -xzf targetfile.tgz Repetier-Server On the new pi unpack it before installing. Normal update will not delete these only if you install a new image. But none the less it is a good idea to have a backup in case disk fails os something goes wrong and files get destroyed.
We plan a backup function in a later stage where you also can select what to backup, but that is future. A button does not work as you need a target that is writable and has enough space. So you need to enter that but with view from server side.
cd /var/lib
