0.85 works, but not anymore with 0.85.1
Thanks for adding support for Smoothie firmware so quickly!
I updated to 0.85 and it worked fine.
However, it seems like the 0.85.1 version doesn't work anymore. I can only access locally from my server, not from any LAN computer/smartphone. Didn't tried WAN however.
Tried restarting the service, uninstalled and started with a fresh 0.85.1 install and still doesn't work.
Had to revert to 0.80.3 since I can't find the 0.85.0 installation.
Which os and version are you running, so I can check it.
<disableIPV6>true</disableIPV6>
in Repetier-Server.xml solves the problem after restart. Working on an update with fix.
