Problems with updatde 0.80.3
I went update the Repetier server via ssh with command: dpkg -i Repetier-Server.0.80.3.deb and returned this error:
You may see warnings about groups. These can be ignored.
O usuário 'repetierserver' já é um membro de 'tty'.
adduser: O grupo 'intserial' não existe.
adduser: O grupo 'ugpio' não existe.
Failed to get D-Bus connection: No connection to service manager.
ln -s '/lib/systemd/system/RepetierServer.service' '/etc/systemd/system/multi-user.target.wants/RepetierServer.service'
RepetierServer: unrecognized service
dpkg: erro ao processar o pacote repetier-server (--install):
sub-processo script post-installation instalado retornou estado de saída de erro 1
A processar 'triggers' para ureadahead (0.100.0-16) ...
Erros foram encontrados durante o processamento de:
repetier-server
Anybody can help me?
Sorry if my english is bad!
I assume after these error that the server is not running?
I do not speak this language or error messages so I don't know what they say. Important is that you have a debian like OS which you seem to have and that sudo is set up ("sudo ls" for example should work).
