Remote Rendering Fails: Unsafe file name
A previously reported issue with Repetier-Server (https://forum.repetier.com/discussion/comment/6150/) appears to still exist when using a remote server to do video rendering. Running 0.80.3 with ffmpeg version 3.2.4. I might be able to work around this by replacing ffmpeg with avconv on the remote server. Will test and report.
james Repetier-Server $ cat tmp/2fb4537c-9a7c-4ad4-a423-b15159ddaef2/settings.json
"bitrate" : 1000,
"conversionError" : "[concat @ 0x7dddc0] Unsafe file name '/var/lib/Repetier-Server/tmp/2fb4537c-9a7c-4ad4-a423-b15159ddaef2/image_00000000.jpg'/var/lib/Repetier-Server/tmp/2fb4537c-9a7c-4ad4-a423-b15159ddaef2/input.txt: Operation not permitted",
"conversionMode" : 3,
"createdSeconds" : 1493938730,
"dir" : "20170504T225850_Kobayashi_Fidget_Cube",
"firstFrameSec" : 1,
"framerate" : 10,
"imageCounter" : 2,
"includeWatermark" : true,
"lastFrameSec" : 1,
"name" : "Kobayashi_Fidget_Cube",
"timelapseBitrate" : 1000,
"valid" : true,
"videoLength" : 84891,
"watermarkPosition" : 0,
"webcamOrientation" : 0
