Killing my head with Wifi on Raspberry !
Hi
I installed the Raspberry image you list on website on a Raspberry 3. First time I started it, I made configuration of server including connect it at my Wifi through the Web Interface.
I made also the modification listed in FAQ to prevent deletion of Wifi configuration if it looses Wifi or restart while Wifi is off.
My only problem is that now it always start in AP mode. If I select my Wifi in web interface it doesn't ask for password ! I loose network connection during 30s and then it goes back in AP mode.
Can I fill all Wifi details in the server.conf file in the Raspberry ? and if so how to tell him to consider these settings to access an AP and not be an AP ?
Thanks,
Vincèn
