Unwanted pause during printing!!!
As i've already reported i've this annoying problem with Repetier Server and Raspberry PI 3.
During printing stops random like in the video, of course, creating imperfections.
Probably the data transfer on USB port is lost for a moment, and then recovers.
From the print log I do not see anything abnormal.
Tried same gcode with "Octoprint" without any issue, same good result when printing from SD, so it's not a Raspberry or printer problem!!!
I hope that as soon as it's released a new server version that fixes this annoying problem.
If the product was free we should be content, but having paid Repetier Server license and i wish more reliability.
Bests,
Marco
Bests,
Marco
So i can confirm, the problem is the wifi network manager! ;-)
I'm sorry, the problem is here again!
Now i try to install a fresh copy of Repetier Server on Octoprint SD image...
Tried with "OctoPrint SD", i've only installed Repetier Server for Armel (with dpkg) and recovery my backup from "/var/lib/Repetier-Sever" of my other "Repetier Server SD", same printing issue, but if i print with the same SD with Octoprint all work fine, both daemon are in execution.
Then i try to disabled the "write log during printing" in your original SD image and at the moment, after 2 hours, no issue with Repetier Server.
My SD is Class 10, so please check the "sd write" routine of the log during printing, I strongly suspect that it's the problem.
