Using talking to my Ramps with Repetier-Server via Bluetooth
Ok I think I have gone off the rails and this is driving me mad.
(first of all first time caller but I brought the pro version late last year and I am still very happy with my purchase of such a great product)
I am setting up the electronics for my printers (the main one is outside in a large metal box and that has the Repeiter-Server installed on a Raspberry Pi. it talks to the main printer with USB so there are no issues there.
The second printer is inside and I want to control that with bluetooth on a Ramps 1.4 board this is the one I am having problems with.
I believe the Jy-mcu module is working because after configuring it to 115200 I can read text I am sending to it from the pi in a logic analyzer.
(I should note that I had to type in the /dev/rfcomm0 in the port on the printer settings when I do that the light on the BT module light go static telling me it is connected)
Originally I put the wires from the module from the BT module into D0 and D1 of Aux1. and I would see Repeiter-Server attempting to connect then it would have the broken link icon. when I reverse the connection I would see in the gcode window external reset and ram messages (I think this is from Repeiter-Server and not the device) after doing a search on the fourms, I read that the pins on the ramps needed to be remapped so we would need to connect to pin 17 and pin 18 on aux 4 (what I assume is D16 and D17) I am still getting the same result.
I wonder if it is something I have messed up in the firmware config file (I used both #define BLUETOOTH_SERIAL 2 (as well as -1) and I have changed "bluetoothSerial": 2 in the connection string area)
Any help would be great
Cheers
Stephen
Cheers
Stephen
After a little sleep I now understand better. I chose option A (serial 3) and also checked my BT module (which I have confirmed is at 115200 8,n,1) now when I hook it up I am getting this on the gcode window and I am getting no reply when I send command m119 (can you tell me that the text below is coming from the server or printer and if from the printer why is it cycling ? (I don't have this repeating when I use a USB cable (edit: unless I have a faulty Ramps board))
Edit: Also when it is like this Repeiter-server thinks that the printer is connected but I have 0 temp (normally I have wild values when there is no temp connected like -17 and so on)
still get no reply when I send the m119 command, so you are right in saying the ramps is not happy with that is getting from BT
Thanks for clearing this up and I keep bashing away. I let you know of the outcome
Edit: I did not turn ACK on when I posted before but i do see commands from the server in black on the gcode window
Cheers
When I hook the BT module to a FTDI (serial to usb) which is turn connected to my PC. this is the result I get from the PI
It looks like in one direction it is running fine but the other is at the worng speed, funny config in the raspberry PI or even a faulty BT module. I am about to head into work so I hope to work this out when I get back or even on my next day off
Cheers for pointing me in the right direction
I am wondering if I have a 'few' bad BT modules or even a bad BT dongle connected to the pi. I tried a couple of other BT modules for the ramps but I can't even configure them. I wonder if they where duds (anyway I can swap out the dongle on the pi later today and if that fails then I put it down then I order some more BT modules off ebay and use a spare rasp pi with a 2nd Repetier-Server install and truck on (a bit of a waste but it will do while I wait
I let you know how I go
