Why won't extruder2 energize the 2nd hotend
I have repetier 1.6.2 driving my smoothieware on a MKSbase ver1.3 board with dual extrusion on my RepRap printer.
Extruder1 has always worked nicely as a single extruder in Repetier but now that I am advancing to dual extrusion I am having difficulties with the 2nd extruder setup.
What works:
I believe that the firmware & hardware is setup correctly because when using LCD interface I can turn on the temperature to extruder1 or extruder2 and have accurate results reported back in the LCD display and confirmed using my thermometer.
When using Repetier in manual mode I can energize the extruder2 motor & extruder1 motor accurately.
Temperature controls for extruder1 work nicely in manual mode.
What doesn't work:
Turning on extruder2 temperature yields no input to the printer for extruder2 in manual mode.
In manual mode the thermistor reading for extruder2 seems to show thermistor1 information ie. after turning off temperature on extruder1 and turning on temperature for exturder2 the extruder2 temperature reading drops in correspondence to the cooling of extruder1 as verified by my thermometer.
Any thoughts would be greatly appreciated.
Thank you,
Chris
What works:
What doesn't work:
Thank you,
Chris
Where would you like me to place the log file ? seems a bit much to paste here.
Very much appreciated.
The only issue seems to be that I do not have thermal control of extruder2 in manual mode with Repetier.
did you setup repetier host for 2 extruders?
see config->printer settings->extruder-> number of extruders
< 17:38:12.163 : N21 M104 T0 S200*16
> 17:38:12.163 : ok
< 17:38:12.335 : N22 M105*23
> 17:38:12.335 : ok T:23.4 /200.0 0
< 17:38:15.392 : N23 M105*22
> 17:38:15.392 : ok T:23.9 /200.0 0
< 17:43:56.518 : N138 M104 T1 S200*40
> 17:43:56.518 : ok
< 17:43:57.844 : N139 M105*44
> 17:43:57.844 : ok T:199.8 /200.0 0
< 17:44:00.902 : N140 M105*34
> 17:44:00.902 : ok T:199.9 /200.0 0
I will review the smoothieware documentation regarding dual hotend setup to see if there is something that I have missed.
Your feedback is very much appreciated.
Thank you
Chris
Regarding the statement :
"ok T:199.8 /200.0 @67 T1:32.1 /0.0 @0
Is there an action that I can take to correct this ?
Thank you,
Chris
