Multiple Printers and connecting to server
Morning,
I have two printers attached to Repeter-server (running on a Pi 3). One printer is a Delta and one a Cartesian so of course I have two different printer profiles.
To select\change the printer I want to print on in Repetier-Host, I have to select\change it in two spots
First I have to select the printer from the dropdown on the main screen and disconnect (if I don't I cant perform the next steps)
Open the printer settings
Connect to continue
Select the printer from the drop down list
then apply.
Am I doing the right? I would think that it should remember these settings so when I select the printer from the front screen it should know\remember what server printer to point to.
Thanks again
Thanks for the reply.
I still get this when I switch printers.
The image is what I see when I change printers (it automatically connects) and slice an object. Unless I disconnect and reconnect the print button is greyed out. I can "save to server" and it goes to the correct printer on the server.
The option to select the printer is greyed out (also in print settings). So I have to disconnect before changing printer.
I'm going to muddy the water a but I have been testing further. It is a enable\disable toggle thing. Here are the steps to reproduce.
Here are the steps to reproduce it on my computer.
Both printers are online in server.
More info. If NO objects are printing everything works as expected. To reproduce the issue you must be actively printing on one printer.
If one printer is printing (and the other is not). BANG the print function is greyed out incorrectly. I think the button state may be swapped with the first printer (or off by printer-1).
To one printer I can connect and print .
The other one I can connect to it in the Browser in the server page, but when I try to connect from Host, it shows 2 printers with the same name, and it won't even connect ... when I enter the API and hit connect it's like it is connecting to the other printer .
What is the solution to this problem, I really would like to be able to control both printers at the same timeand print in parallel without being connected by USB .
