V0.80.2 Pro - Bad comunication with the printer!
I upgrade my server, now when i try to print the printer doesn't respond.
After an emergency reset i can change bed and hotend temp, but with i try to print something it doesn't work.
In this "freeze" situation Repetier Host connected in lan doesn't read the eeprom settings.
Downgrade to V0.80.1 and same issue (RAMPS 1.4), but the problem is here when upgrade to 0.80.2.
The printer work fine if i execute a job from SD or using Repetier Host with a pc.
What's "destructive" in the new release? ;-)
Marco
Marco
Maybe worth a shot?
> 21:39:31.670: T:209.5 /210.0 B:65.0 /65.0 @:65 B@:110 W:5
> 21:39:32.670: T:209.6 /210.0 B:65.0 /65.0 @:64 B@:99 W:4
> 21:39:33.670: T:209.5 /210.0 B:65.0 /65.0 @:66 B@:100 W:3
> 21:39:34.670: T:209.7 /210.0 B:65.1 /65.0 @:64 B@:95 W:2
> 21:39:35.669: T:209.7 /210.0 B:65.0 /65.0 @:65 B@:99 W:1
> 21:39:36.669: T:209.9 /210.0 B:65.1 /65.0 @:63 B@:92 W:0
> 21:39:36.749: ok
> 21:39:36.749: ok
> 21:39:36.750: ok
> 21:39:36.751: ok
> 21:39:36.751: ok
> 21:39:36.752: ok T:209.9 /210.0 B:65.1 /65.0 @:63 B@:92
> 21:39:36.753: ok
> 21:39:36.754: ok T:209.9 /210.0 B:65.1 /65.0 @:63 B@:92
< 21:39:36.757: M117 Layer 0/50
If I disable power as in my scripts it shows up red and disconnected. When I apply power again the printer goes yellow and then green. Not always. Sometimes it stays white and I have to press Activate at least twice. Three-four times often.
Logging simply **stops** as does the print and code - sometimes mid print.
coincidentally I removed the (cheap) webcam and the problem sopped - but by then i'd gone over to Octoprint.
