Setting up Adafruit 3.5" TFT w/ Repetier Server
After trying to setup Octoprint with a plugin called Octoprint TFT where you can control everything from a small touchscreen I realized the amount of aspirin needed to resurrect that plugin wasn't going to go well. One of the members of the Prusa group I admin mentioned that it's easier and works better on Repetier Server.
Step 7: Install Adafruit Drivers
Step 8: Modify screen config
Step 9: Set Screen Size
Reboot and done.
Easier??? NO. Better? YES!
Documentation was impossible to find to properly make this work even though I found a forum post here that described setting up a different brand screen then finding others having the same issues I was having but the issue not being resolved.
Spent the better part of 3-4 hours setting it up using what I learned from the Octoprint plugin and viola a tiny Repetier Server that I can control from the front of my printer.
Step 1: Install latest RPi version of Repetier Server following normal directions
Step 2: Edit config.txt file
Edit Config.txt file on Boot
Change LCD rotate to 0
lcd_rotate=0
Scroll to this section and make these changes, uncomment 3 lines and single line addition
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
dtoverlay=pitft35-resistive,rotate=90,speed=20000000,fps=20
Save txt file
Step 3: Eject MicroSD card and load up the PI as normal
Step 4: Setup Repetier Server via web interface
Step 5: SSH into your pi
Step 6: Expand the filesystem
sudo raspi-config
Select: 7 Advanced Options => A1 Expand Filesystem
Reboot
wget https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/master/adafruit-pitft.sh
chmod +x adafruit-pitft.sh
sudo ./adafruit-pitft.sh
Option 4 (rotated 90 degrees)
Option 1
Yes
Reboot
sudo nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf
Add the following
Section "Device"
Identifier "adafruitTFT"
Driver "fbdev"
Option "fbdev" "/dev/fb1"
EndSection
^x
Y
sudo nano /usr/share/X11/xorg.conf.d/40-libinput.conf
I added Option "TransformationMatrix" "0 1 0 -1 0 1 0 0 1" in InputClass section dedicated to touchscreens
Section "InputClass"
Identifier "libinput touchscreen catchall"
MatchIsTouchscreen "on"
MatchDevicePath "/dev/input/event*"
Driver "libinput"
EndSection
^x
Y
Step 10: sudo reboot
Should be ready to go but if you need to calibrate the screen here is the step for that
Step 11: Screen Calibration
Manually calibrate screen
sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
Head to screen and manually touch each point to calibrate the screen
Reboot and done.
What's the process in pointing x windows to the correct screen? If you wouldn't mind typing it up like I'm 5 that's would be awesome since I lack the ability to understand how this all works. Coding is my weakness. I prefer hardware. ????
Specifically the "yes" part
is it yes to the console option? if so i cant get it to display anything other than console after doing all the steps.
if its no and then yes to the next question. where it asks if you want it to mirror HDMI.
then in that instance i cannot get it off a White Screen Display.
