RepRap Guru driver?
I have a RepRap guru i3, but that company seems to have gone out of business- their website no longer exists.
I had to reimage my computer, and I have lost the ability to talk directly to my printer through Repetier Host, and I can't figure out how to get it back.
When I plug the printer in to my computer, I get a notice that "Unknown device" needs a driver
Does anyone know where I can find that driver?
  • You could try installing arduino ide with drivers in case they have the same serial driver as normal arduinos. May printers have. Otherwise check in hardware settings settings for VID and PID of the usb connection and search a driver for that. Last chance is to use linux instead. Normally they are compiled in linux.
  • That sort of worked. My computer is now talking to my printer via Repetier, but one of them won't shut up: I can't print, because there is a constant stream of commands or messages flowing between them, and when I try to print, the printer starts to respond, then the job is killed by Repetier.
    The set of messages just keeps repeating:
    19:04:14.547 : start
    19:04:14.547 : echo:Marlin 1.1.6
    19:04:14.547 : echo: Last Updated: 2017-10-10 12:00 | Author: (RepRapGuru Prusa i3 V4,11/27/17)
    19:04:14.547 : echo:Compiled: Jul 11 2018
    19:04:14.547 : echo: Free Memory: 4023  PlannerBufferBytes: 1232
    19:04:14.547 : echo:Hardcoded Default Settings Loaded
    19:04:14.547 : echo:  G21    ; Units in mm
    19:04:14.557 : echo:  M149 C ; Units in Celsius
    19:04:14.557 : echo:Filament settings: Disabled
    19:04:14.557 : echo:  M200 D3.00
    19:04:14.557 : echo:  M200 D0
    19:04:14.557 : echo:Steps per unit:
    19:04:14.557 : echo:  M92 X80.00 Y80.00 Z4000.00 E90.00
    19:04:14.557 : echo:Maximum feedrates (units/s):
    19:04:14.567 : echo:  M203 X250.00 Y250.00 Z2.00 E22.00
    19:04:14.567 : echo:Maximum Acceleration (units/s2):
    19:04:14.567 : echo:  M201 X1000 Y1000 Z5 E1000
    19:04:14.567 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
    19:04:14.567 : echo:  M204 P500.00 R500.00 T750.00
    19:04:14.577 : echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
    19:04:14.577 : echo:  M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
    19:04:14.577 : echo:Home offset:
    19:04:14.577 : echo:  M206 X0.00 Y0.00 Z0.00
    19:04:14.577 : echo:Material heatup parameters:
    19:04:14.587 : echo:  M145 S0 H180 B70 F255
    19:04:14.587 : M145 S1 H225 B100 F255
    19:04:14.587 : echo:PID settings:
    19:04:14.587 : echo:  M301 P22.20 I1.08 D114.00
    19:04:14.667 : N1 M110*34
    19:04:14.667 : N2 M115*36
    19:04:14.667 : N3 M105*36
    19:04:14.667 : N4 M114*35
    19:04:14.667 : N5 M111 S6*98
    19:04:14.677 : N6 T0*60
    19:04:14.677 : N7 M20*22
    19:04:14.677 : N8 M80*19
    19:04:17.087 : N9 M20*24
    19:04:17.087 : echo:SD card ok
    19:04:17.147 : N10 M220 S100*80
    19:04:17.147 : Cap:EEPROM:0
    19:04:17.147 : Cap:AUTOREPORT_TEMP:1
    19:04:17.147 : Cap:PROGRESS:0
    19:04:17.147 : Cap:PRINT_JOB:1
    19:04:17.147 : Cap:AUTOLEVEL:0
    19:04:17.147 : Cap:Z_PROBE:0
    19:04:17.147 : Cap:LEVELING_DATA:0
    19:04:17.147 : Cap:SOFTWARE_POWER:1
    19:04:17.147 : Cap:TOGGLE_LIGHTS:0
    19:04:17.147 : Cap:CASE_LIGHT_BRIGHTNESS:0
    19:04:17.157 : Cap:EMERGENCY_PARSER:0
    19:04:17.157 : N11 M221 S100*80
    19:04:17.157 : N12 M111 S6*84
    19:04:17.157 : echo:DEBUG:INFO,ERRORS
    19:04:17.157 : echo:Active Extruder: 0
    19:04:17.157 : Begin file list
    19:04:17.157 : N13 T0*8
    19:04:17.157 : N14 M155 S1*85
    19:04:17.347 : /PRODUC~1/LABELS/MINI_V~1.GLA 182805
    19:04:17.347 : /PRODUC~1/LABELS/MINI_V~2.GLA 182805
    19:04:17.347 : /PRODUC~1/LABELS/MINI_V~3.GLA 684243
    19:04:17.637 : /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~1.GBR 52693
    19:04:17.647 : /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~2.GBR 1316
    19:04:17.647 : /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~3.GBR 504
    19:04:17.647 : /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~4.GBR 112543
    19:04:17.647 : /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~5.GBR 2728
    19:04:17.657 : /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~6.GBR 1617
    19:04:17.657 : /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~7.GBR 35616
    19:04:17.745 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.G2 284845
    19:04:17.745 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBL 267769
    19:04:17.755 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBO 54687
    19:04:17.755 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBP 1219
    19:04:17.765 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBS 9983
    19:04:17.765 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GD1 131217
    19:04:17.765 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GG1 63023
    19:04:17.765 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GM2 2166
    19:04:17.775 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GM8 195
    19:04:17.775 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GP1 15236
    19:04:17.785 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTL 401243
    19:04:17.785 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTO 81259
    19:04:17.785 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTP 26636
    19:04:17.795 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTS 31314
    19:04:17.795 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.G2 302082
    19:04:17.805 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBL 282661
    19:04:17.805 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBO 55799
    19:04:17.815 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBP 761
    19:04:17.815 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBS 9718
    19:04:17.815 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GD1 113608
    19:04:17.815 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GG1 64676
    19:04:17.825 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GM2 2122
    19:04:17.825 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GM8 221
    19:04:17.835 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GP1 15101
    19:04:17.835 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTL 470203
    19:04:17.835 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTO 83281
    19:04:17.835 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTP 26878
    19:04:17.845 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTS 31386
    19:04:17.845 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.G2 302082
    19:04:17.855 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBL 282661
    19:04:17.855 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBO 55799
    19:04:17.865 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBP 761
    19:04:17.865 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBS 9718
    19:04:17.865 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GD1 113608
    19:04:17.875 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GG1 64676
    19:04:17.875 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GM2 2122
    19:04:17.875 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GM8 221
    19:04:17.885 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GP1 15101
    19:04:17.885 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTL 470203
    19:04:17.885 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTO 83185
    19:04:17.895 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTP 26878
    19:04:17.895 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTS 31386
    19:04:17.965 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.G1 597291
    19:04:17.965 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.G2 792609
    19:04:17.975 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.G3 276712
    19:04:17.975 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GBL 751027
    19:04:17.975 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GBO 151226
    19:04:17.975 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GBS 25698
    19:04:17.985 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GD1 559576
    19:04:17.985 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GM1 2355
    19:04:17.995 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GM2 7761
    19:04:17.995 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GM3 4728
    19:04:17.995 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~2.GM3 2267
    19:04:17.995 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~3.GM3 2533
    19:04:18.005 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GP1 41148
    19:04:18.005 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTL 1233814
    19:04:18.015 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTO 227592
    19:04:18.015 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTP 65956
    19:04:18.015 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTS 75364
    19:04:18.065 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.G1 600702
    19:04:18.069 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.G2 795243
    19:04:18.073 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.G3 278203
    19:04:18.073 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GBL 753079
    19:04:18.077 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GBO 151203
    19:04:18.081 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GBS 25690
    19:04:18.086 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GD1 561128
    19:04:18.090 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GM1 2348
    19:04:18.091 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GM2 5625
    19:04:18.091 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~2.GM2 7758
    19:04:18.101 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GM3 4725
    19:04:18.101 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~2.GM3 2261
    19:04:18.101 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~3.GM3 2527
    19:04:18.101 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GP1 41283
    19:04:18.111 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTL 1229884
    19:04:18.111 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTO 227808
    19:04:18.121 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTP 66378
    19:04:18.121 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTS 75786
    19:04:18.161 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.G1 596727
    19:04:18.171 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.G2 781847
    19:04:18.171 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.G3 236734
    19:04:18.171 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GBL 739066
    19:04:18.171 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GBO 152446
    19:04:18.181 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GBS 25156
    19:04:18.181 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GD1 564729
    19:04:18.191 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GM1 969
    19:04:18.191 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GM2 5625
    19:04:18.191 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~2.GM2 6443
    19:04:18.191 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GM3 3413
    19:04:18.191 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~2.GM3 924
    19:04:18.201 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~3.GM3 1186
    19:04:18.201 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GP1 41441
    19:04:18.211 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTL 1097495
    19:04:18.211 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTO 225154
    19:04:18.221 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTP 65917
    19:04:18.221 : /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTS 76056
    19:04:18.501 : /PRODUC~2/PRINTE~1/USB_SU~1/M2_PP-~1.GCO 3788986
    19:04:18.501 : /PRODUC~2/PRINTE~1/USB_SU~1/PP-GP0~1.GCO 3788450
    19:04:18.511 : /PRODUC~2/PRINTE~1/X_BEAR~1/MINI2/AS-PR0~1.GCO 12942332
    19:04:18.521 : /PRODUC~2/PRINTE~1/X_BEAR~1/AS-PR0~1.GCO 6908269
    19:04:18.521 : /PRODUC~2/PRINTE~1/X_BEAR~1/AS-PR0~2.GCO 6907732
    19:04:18.531 : /PRODUC~2/PRINTE~1/HEATSI~1/M2_PP-~1.GCO 1087374
    19:04:18.531 : /PRODUC~2/PRINTE~1/HEATSI~1/PP-GP0~1.GCO 1084911
    19:04:18.551 : /PRODUC~2/PRINTE~1/LCD_PR~1/LCD_MI~1/MINI/PP-GP0~1.GCO 3695513
    19:04:18.571 : /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~1/MINI/PP-GP0~1.GCO 2000398
    19:04:18.581 : /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~2/MINI/PP-GP0~1.GCO 3342906
    19:04:18.601 : /PRODUC~2/PRINTE~1/LCD_PR~1/SIDE_C~1/MINI/PP-GP0~1.GCO 2998214
    19:04:18.611 : /PRODUC~2/PRINTE~1/LCD_PR~1/TOP_CA~1/MINI/PP-GP0~1.GCO 2120384
    19:04:18.621 : /PRODUC~2/PRINTE~1/LCD_PR~1/COVER_~1/M2_PP-~1.GCO 214510
    19:04:18.621 : /PRODUC~2/PRINTE~1/LCD_PR~1/COVER_~1/PP-GP0~1.GCO 212074
    19:04:18.641 : /PRODUC~2/PRINTE~1/LCD_PR~1/LCD_SP~1/MINI/PP-GP0~1.GCO 6636259
    19:04:18.661 : /PRODUC~2/PRINTE~1/LCD_PR~1/LCD_SP~1/TAZ6/LCD_SP~1.GCO 3491336
    19:04:18.671 : /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~3/PP-GP0~1.GCO 1182449
    19:04:18.691 : /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~4/MINI/PP-GP0~1.GCO 8592746
    19:04:18.701 : /PRODUC~2/PRINTE~1/BED_CLIP/PP-GP0~1.GCO 5378707
    19:04:18.711 : /PRODUC~2/PRINTE~1/BED_CO~1/MINI/PP-GP0~1.GCO 5006769
    19:04:18.721 : /PRODUC~2/PRINTE~1/BED_CO~1/TAZ/PP-GP0~1.GCO 7945967
    19:04:18.741 : /PRODUC~2/PRINTE~1/X_CARR~1/AS-PR0~1.GCO 5184974
    19:04:18.741 : /PRODUC~2/PRINTE~1/X_CARR~1/MINI2/AS-PR0~1.GCO 5185666
    19:04:18.761 : /PRODUC~2/PRINTE~1/BELT_T~1/M2_PP-~1.GCO 4320816
    19:04:18.761 : /PRODUC~2/PRINTE~1/BELT_T~1/PP-GP0~1.GCO 4318723
    19:04:18.781 : /PRODUC~2/PRINTE~1/Y-SING~1/AS-PR0~1.GCO 10464815
    19:04:18.781 : /PRODUC~2/PRINTE~1/Y-SING~1/MINI2/M2_AS-~1.GCO 10465415
    19:04:18.801 : /PRODUC~2/PRINTE~1/BLOWER~1/M2_PP-~1.GCO 3054946
    19:04:18.801 : /PRODUC~2/PRINTE~1/BLOWER~1/PP-GP0~1.GCO 3052480
    19:04:18.821 : /PRODUC~2/PRINTE~1/BUMP_S~1/TAZPRI~1/PP-GP0~1.GCO 8252560
    19:04:18.821 : /PRODUC~2/PRINTE~1/BUMP_S~1/PP-GP0~1.GCO 4348184
    19:04:18.851 : /PRODUC~2/PRINTE~1/DOUBLE~1/MINI2/M2_AS-~1.GCO 15146592
    19:04:18.861 : /PRODUC~2/PRINTE~1/EXTRUD~1/PP-GP0~1.GCO 2988303
    19:04:18.871 : /PRODUC~2/PRINTE~1/EXTRUD~1/MINI2/M2_PP-~1.GCO 2988840
    19:04:18.891 : /PRODUC~2/PRINTE~1/HANDLE/PP-GP0~1.GCO 10080261
    19:04:18.911 : /PRODUC~2/PRINTE~1/RETAIN~1/M2_PP-~1.GCO 1800852
    19:04:18.911 : /PRODUC~2/PRINTE~1/RETAIN~1/PP-GP0~1.GCO 1798756
    19:04:18.921 : /PRODUC~2/PRINTE~1/SPOOL-~1/PP-GP0~1.GCO 4816442
    19:04:18.941 : /PRODUC~2/PRINTE~1/SPOOL-~2/PP-GP0~1.GCO 3409265
    19:04:18.961 : /PRODUC~2/PRINTE~1/SPOOL_~1/PP-GP0~1.GCO 7157246
    19:04:18.961 : /PRODUC~2/PRINTE~1/SPOOL_~1/PP-GP0~2.GCO 9220572
    19:04:18.981 : /PRODUC~2/PRINTE~1/STRAIN~1/PP-GP0~1.GCO 6997279
    19:04:19.001 : /PRODUC~2/PRINTE~1/STRAIN~2/PP-GP0~1.GCO 7835002
    19:04:19.031 : /PRODUC~2/PRINTE~1/UNTHRE~1/UNTHRE~1/MINI2/M2_PP-~1.GCO 3856127
    19:04:19.031 : /PRODUC~2/PRINTE~1/UNTHRE~1/UNTHRE~1/PP-GP0~1.GCO 3853124
    19:04:19.051 : /PRODUC~2/PRINTE~1/WIPER_~1/PP-GP0~1.GCO 6342912
    19:04:19.077 : /PRODUC~2/PRINTE~1/X_BELT~1/M2_PP-~1.GCO 5876216
    19:04:19.077 : /PRODUC~2/PRINTE~1/X_BELT~1/M2_PP-~2.GCO 28458624
    19:04:19.077 : /PRODUC~2/PRINTE~1/X_BELT~1/PP-GP0~1.GCO 5873994
    19:04:19.077 : /PRODUC~2/PRINTE~1/X_BELT~1/PP-GP0~2.GCO 28456510
    19:04:19.097 : /PRODUC~2/PRINTE~1/X_CARR~2/M2_PP-~1.GCO 3894768
    19:04:19.107 : /PRODUC~2/PRINTE~1/X_CARR~2/PP-GP0~1.GCO 3892463
    19:04:19.127 : /PRODUC~2/PRINTE~1/X_END_~1/AS-PR0~1.GCO 11816991
    19:04:19.147 : /PRODUC~2/PRINTE~1/X_END_~2/AS-PR0~1.GCO 12487272
    19:04:19.167 : /PRODUC~2/PRINTE~1/Y-IDLER/MINI2/PP-GP0~1.GCO 8437933
    19:04:19.167 : /PRODUC~2/PRINTE~1/Y-IDLER/PP-GP0~1.GCO 8437417
    19:04:19.197 : /PRODUC~2/PRINTE~1/Y-MOTO~1/PP-GP0~1.GCO 9864280
    19:04:19.217 : /PRODUC~2/PRINTE~1/Z_BELT~1/M2_PP-~1.GCO 2180033
    19:04:19.217 : /PRODUC~2/PRINTE~1/Z_BELT~1/PP-GP0~1.GCO 2177538
    19:04:19.237 : /PRODUC~2/PRINTE~1/Z_BRAK~1/M2_PP-~1.GCO 5662286
    19:04:19.247 : /PRODUC~2/PRINTE~1/Z_BRAK~1/PP-GP0~1.GCO 5659741
    19:04:19.267 : /PRODUC~2/PRINTE~1/Z_LOWE~1/M2_PP-~1.GCO 2388652
    19:04:19.267 : /PRODUC~2/PRINTE~1/Z_LOWE~1/PP-GP0~1.GCO 2386222
    19:04:19.297 : /PRODUC~2/PRINTE~1/Z_LOWE~2/M2_PP-~1.GCO 2387589
    19:04:19.297 : /PRODUC~2/PRINTE~1/Z_LOWE~2/PP-GP0~1.GCO 2385158
    19:04:19.317 : /PRODUC~2/PRINTE~1/Z_UPPE~1/M2_PP-~1.GCO 5861211
    19:04:19.317 : /PRODUC~2/PRINTE~1/Z_UPPE~1/PP-GP0~1.GCO 5858694
    19:04:19.347 : /PRODUC~2/PRINTE~1/Z_UPPE~2/M2_PP-~1.GCO 5160175
    19:04:19.347 : /PRODUC~2/PRINTE~1/Z_UPPE~2/PP-GP0~1.GCO 5157655
    19:04:19.367 : /PRODUC~2/PRINTE~1/BELT-C~1/PP-GP0~1.GCO 1591183
    19:04:19.397 : /PRODUC~2/PRINTE~1/BELT-M~1/PP-GP0~1.GCO 17782880
    19:04:19.667 : /SAMPLE~1/CALIBR~1/NON-PL~1.GCO 515
    19:04:19.667 : /SAMPLE~1/CALIBR~1/OCTO_S~1.GCO 13508
    19:04:19.667 : /SAMPLE~1/CALIBR~1/V2AERO~1.GCO 1688911
    19:04:19.667 : /SAMPLE~1/CALIBR~1/PLA_HS~1.GCO 198948
    19:04:19.677 : /SAMPLE~1/CALIBR~1/HIBISC~1.GCO 6281
    19:04:19.677 : /SAMPLE~1/CALIBR~1/HIBISC~2.GCO 703
    19:04:19.677 : /SAMPLE~1/CALIBR~1/Z-BELT~1.GCO 835
    19:04:19.677 : /SAMPLE~1/CALIBR~1/Z_SHIP~1.GCO 527
    19:04:19.687 : /SAMPLE~1/CALIBR~1/MINI2_~1.GCO 1342
    19:04:19.687 : /SAMPLE~1/CALIBR~1/MINI2_~2.GCO 2088
    19:04:19.697 : /SOFTWARE/LULZBO~1.GCO 2461
    19:04:20.927 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~1.GCO 1057
    19:04:20.927 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~2.GCO 1005
    19:04:20.937 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~3.GCO 808
    19:04:20.937 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~4.GCO 619
    19:04:20.937 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~5.GCO 626
    19:04:20.947 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~6.GCO 619
    19:04:20.947 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~7.GCO 626
    19:04:20.947 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~8.GCO 1141
    19:04:20.957 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~9.GCO 457
    19:04:20.957 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU254E~4.GCO 2564
    19:04:20.957 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU254F~4.GCO 1651
    19:04:20.967 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2550~4.GCO 2498
    19:04:20.967 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2553~4.GCO 3114
    19:04:20.967 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2554~4.GCO 2888
    19:04:20.977 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2557~4.GCO 2493
    19:04:20.977 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU254C~4.GCO 1051
    19:04:20.977 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU255A~4.GCO 1146
    19:04:20.987 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2544~4.GCO 1133
    19:04:20.987 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU255F~4.GCO 1294
    19:04:20.987 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2549~4.GCO 1011
    19:04:20.997 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2562~4.GCO 1051
    19:04:20.997 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2563~4.GCO 2352
    19:04:20.997 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2566~4.GCO 1214
    19:04:21.007 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU255B~4.GCO 4269
    19:04:21.007 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2569~4.GCO 5187
    19:04:21.007 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU256A~4.GCO 980
    19:04:21.017 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU256D~4.GCO 3891
    19:04:21.017 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2541~4.GCO 897
    19:04:21.017 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2572~4.GCO 3032
    19:04:21.027 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2573~4.GCO 2297
    19:04:21.027 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2575~4.GCO 1474
    19:04:21.027 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2576~4.GCO 718
    19:04:21.037 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2578~4.GCO 757
    19:04:21.037 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2579~4.GCO 2361
    19:04:21.047 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU257C~4.GCO 1327
    19:04:21.047 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2571~4.GCO 5318
    19:04:21.047 : /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU2581~4.GCO 2919
  • You should post the log around the error, not a successful part of connecting. All I see here is that you have a sd card with lots of files on it. Maybe too much files triggering a problem. Seems like it contains the full cura sources and not just a few gcodes.
    What I posted is everything that I see. It repeats that block of messages. Nothing else that I can see.
    I will try using an SD card that is clean.
  • or, DUH, I could just remove the SD card.
    That fixed the problem.
