Error:Line Number is not Last Line Number+1, Last Line:
Bonjour à tous,
Voici mon problème:
15:27:22.071 : Impression couche layer 3 sur 3
15:27:22.071 : N297 G1 F50 X49.644 Y54.649 E4.4132*60
15:27:22.071 : N298 G1 X49.644 Y55.217 E4.4221*95
15:27:22.071 : N299 G1 X49.645 Y55.946 E4.43353*103
15:27:22.071 : N300 G1 X49.647 Y57.09 E4.45146*84
15:27:22.071 : N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.071 : N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.071 : N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.071 : N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.071 : N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.071 : N306 G1 X49.649 Y60.742 E4.50871*105
15:27:22.071 : N307 G1 X49.649 Y61.116 E4.51457*103
15:27:22.071 : Error:checksum mismatch, Last Line: 300
15:27:22.086 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.086 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.086 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.086 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.086 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.086 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.102 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.102 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.102 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.102 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.102 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.102 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.118 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.118 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.118 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.118 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.118 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.134 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.134 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.134 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.134 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.134 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.134 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.149 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.149 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.149 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.149 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.149 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.149 : Error:Line Number is not Last Line Number+1, Last Line: 305
15:27:22.149 : Resend: N306 G1 X49.649 Y60.742 E4.50871*105
15:27:22.149 : Resend: N307 G1 X49.649 Y61.116 E4.51457*103
15:27:22.149 : N308 M117 FIN 4m 23s*101
15:27:22.165 : Resend: N306 G1 X49.649 Y60.742 E4.50871*105
15:27:22.165 : Resend: N307 G1 X49.649 Y61.116 E4.51457*103
15:27:22.165 : Resend: N308 M117 FIN 4m 23s*101
J'ai changé mon câble mais toujours le même problème. De plus, ces erreurs ne sont jamais au même endroit (même lignes). Puis à cause de ces erreurs le logiciels bloque l'impression à des endroits aléatoires.
Comment peut-on résoudre ce problème?
Toute aide est la bienvenue
Merci d'avance
Emeline
I think either baud rate is not 100% correct or input buffer was set too high. Try 127 and if it stays 63.
What is input buffer? Where I change the number to 127?
