RepetierServer on Raspberry, wifi switches to AP mode
I'm running repetierserver on 0.90.2 on a raspberry. When I boot, all works well, can access, upload and print to my FelixPro2. No problem. However after a day or 2 the network (192.168.2.107) switches back to Access Point mode (10.10.10.1). Meanwhile also touching 169.254.115.215 for some reason....
This is consistent for weeks now. When I connect to the AP, and re-connect the ReptierServer to my router it is accessable over the network again for some time. Below the syslog output of the time around when it seems to switch from dhcp client to AP. Router SSID = thor.
Does this output help in any way tracking down the cause of the problem?
Thx
Mike
===========syslog output=================
Aug 6 07:15:54 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) successful, device activated.
Aug 6 07:15:54 RepetierServer nm-dispatcher: Dispatching action 'up' for wlan0
Aug 6 07:15:55 RepetierServer dhcpcd[614]: wlan0: rebinding lease of 192.168.2.107
Aug 6 07:15:55 RepetierServer dhcpcd[614]: wlan0: changing route to 192.168.2.0/24
Aug 6 07:15:55 RepetierServer dhcpcd[614]: wlan0: changing default route via 192.168.2.254
Aug 6 07:15:57 RepetierServer ntpd[656]: Listen normally on 15 wlan0 192.168.2.107 UDP 123
Aug 6 07:15:59 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
Aug 6 07:15:59 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) started...
Aug 6 07:15:59 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Aug 6 07:16:12 RepetierServer dhcpcd[614]: wlan0: carrier lost
Aug 6 07:16:12 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Aug 6 07:16:12 RepetierServer avahi-daemon[399]: Withdrawing address record for 192.168.2.107 on wlan0.
Aug 6 07:16:12 RepetierServer avahi-daemon[399]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.2.107.
Aug 6 07:16:12 RepetierServer dhcpcd[614]: wlan0: deleting route to 192.168.2.0/24
Aug 6 07:16:12 RepetierServer avahi-daemon[399]: Interface wlan0.IPv4 no longer relevant for mDNS.
Aug 6 07:16:12 RepetierServer dhcpcd[614]: wlan0: deleting default route via 192.168.2.254
Aug 6 07:16:13 RepetierServer NetworkManager[2934]: <info> (wlan0): roamed from BSSID 08:60:6E:CB:03:70 (thor) to (none) ((none))
Aug 6 07:16:14 RepetierServer ntpd[656]: Deleting interface #15 wlan0, 192.168.2.107#123, interface stats: received=4, sent=4, dropped=0, active_time=17 secs
Aug 6 07:19:05 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: activated -> deactivating (reason 'user-requested') [100 110 39]
Aug 6 07:19:05 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: deactivating -> disconnected (reason 'user-requested') [110 30 39]
Aug 6 07:19:05 RepetierServer NetworkManager[2934]: <info> (wlan0): deactivating device (reason 'user-requested') [39]
Aug 6 07:19:05 RepetierServer NetworkManager[2934]: <info> (wlan0): canceled DHCP transaction, DHCP client pid 29728
Aug 6 07:19:05 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-DISCONNECTED bssid=08:60:6e:cb:03:70 reason=3 locally_generated=1
Aug 6 07:19:05 RepetierServer nm-dispatcher: Dispatching action 'down' for wlan0
Aug 6 07:19:05 RepetierServer NetworkManager[2934]: <info> (wlan0): supplicant interface state: completed -> disconnected
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) starting connection 'Hotspot'
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0/wireless): connection 'Hotspot' has security, and secrets exist. No new secrets needed.
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Aug 6 07:19:06 RepetierServer wpa_supplicant[595]: Failed to create interface mon.wlan0: -95 (Operation not supported)
Aug 6 07:19:06 RepetierServer wpa_supplicant[595]: wlan0: Could not connect to kernel driver
Aug 6 07:19:06 RepetierServer wpa_supplicant[595]: Using interface wlan0 with hwaddr b8:27:eb:a7:26:37 and ssid "RepetierServer"
Aug 6 07:19:06 RepetierServer dhcpcd[614]: wlan0: carrier acquired
Aug 6 07:19:06 RepetierServer wpa_supplicant[595]: wlan0: interface state UNINITIALIZED->ENABLED
Aug 6 07:19:06 RepetierServer wpa_supplicant[595]: wlan0: AP-ENABLED
Aug 6 07:19:06 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-CONNECTED - Connection to b8:27:eb:a7:26:37 completed [id=0 id_str=]
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> (wlan0): supplicant interface state: disconnected -> completed
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot 'RepetierServer'.
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Aug 6 07:19:06 RepetierServer dhcpcd[614]: wlan0: IAID eb:a7:26:37
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) started...
Aug 6 07:19:06 RepetierServer avahi-daemon[399]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.10.10.1.
Aug 6 07:19:06 RepetierServer avahi-daemon[399]: New relevant interface wlan0.IPv4 for mDNS.
Aug 6 07:19:06 RepetierServer avahi-daemon[399]: Registering new address record for 10.10.10.1 on wlan0.IPv4.
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol tcp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:06 RepetierServer dhcpcd[614]: wlan0: rebinding lease of 192.168.2.107
Aug 6 07:19:06 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol udp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:07 RepetierServer dhcpcd[614]: wlan0: soliciting an IPv6 router
Aug 6 07:19:07 RepetierServer wpa_supplicant[595]: wlan0: Could not connect to kernel driver
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol tcp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:07 RepetierServer wpa_supplicant[595]: Using interface wlan0 with hwaddr b8:27:eb:a7:26:37 and ssid "RepetierServer"
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol udp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --in-interface wlan0 --jump REJECT
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --out-interface wlan0 --jump REJECT
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --in-interface wlan0 --out-interface wlan0 --jump ACCEPT
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --source 10.10.10.0/255.255.255.0 --in-interface wlan0 --j
ump ACCEPT
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --destination 10.10.10.0/255.255.255.0 --out-interface wla
n0 --match state --state ESTABLISHED,RELATED --jump ACCEPT
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: ip-config -> ip-check (reason 'none') [70 80 0]
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete.
Aug 6 07:19:07 RepetierServer wpa_supplicant[595]: wlan0: interface state UNINITIALIZED->ENABLED
Aug 6 07:19:07 RepetierServer wpa_supplicant[595]: wlan0: AP-ENABLED
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: ip-check -> secondaries (reason 'none') [80 90 0]
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: secondaries -> activated (reason 'none') [90 100 0]
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) successful, device activated.
Aug 6 07:19:07 RepetierServer nm-dispatcher: Dispatching action 'up' for wlan0
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> (wlan0): disconnecting for new activation request.
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: activated -> deactivating (reason 'none') [100 110 0]
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: deactivating -> disconnected (reason 'none') [110 30 0]
Aug 6 07:19:07 RepetierServer NetworkManager[2934]: <info> (wlan0): deactivating device (reason 'none') [0]
Aug 6 07:19:08 RepetierServer avahi-daemon[399]: Interface wlan0.IPv4 no longer relevant for mDNS.
Aug 6 07:19:08 RepetierServer dhcpcd[614]: wlan0: carrier lost
Aug 6 07:19:08 RepetierServer avahi-daemon[399]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.10.10.1.
Aug 6 07:19:08 RepetierServer avahi-daemon[399]: Withdrawing address record for 10.10.10.1 on wlan0.
Aug 6 07:19:08 RepetierServer avahi-daemon[399]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.10.10.1.
Aug 6 07:19:08 RepetierServer avahi-daemon[399]: New relevant interface wlan0.IPv4 for mDNS.
Aug 6 07:19:08 RepetierServer avahi-daemon[399]: Registering new address record for 10.10.10.1 on wlan0.IPv4.
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) starting connection 'Hotspot'
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --destination 10.10.10.0/255.255.255.0 --out-interface wla
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --source 10.10.10.0/255.255.255.0 --in-interface wlan0 --j
ump ACCEPT
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --in-interface wlan0 --out-interface wlan0 --jump ACCEPT
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --out-interface wlan0 --jump REJECT
Aug 6 07:19:08 RepetierServer nm-dispatcher: Dispatching action 'down' for wlan0
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --in-interface wlan0 --jump REJECT
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol udp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol tcp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol udp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol tcp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> (wlan0): supplicant interface state: completed -> disconnected
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0/wireless): access point 'Hotspot' has security, but secrets are required.
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: config -> need-auth (reason 'none') [50 60 0]
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Aug 6 07:19:08 RepetierServer NetworkManager[2934]: <info> Activation (wlan0/wireless): connection 'Hotspot' has security, and secrets exist. No new secrets needed.
Aug 6 07:19:09 RepetierServer wpa_supplicant[595]: wlan0: Could not connect to kernel driver
Aug 6 07:19:09 RepetierServer wpa_supplicant[595]: Using interface wlan0 with hwaddr b8:27:eb:a7:26:37 and ssid "RepetierServer"
Aug 6 07:19:09 RepetierServer dhcpcd[614]: wlan0: carrier acquired
Aug 6 07:19:09 RepetierServer wpa_supplicant[595]: wlan0: interface state UNINITIALIZED->ENABLED
Aug 6 07:19:09 RepetierServer wpa_supplicant[595]: wlan0: AP-ENABLED
Aug 6 07:19:09 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-CONNECTED - Connection to b8:27:eb:a7:26:37 completed [id=0 id_str=]
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> (wlan0): supplicant interface state: disconnected -> completed
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot 'RepetierServer'.
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Aug 6 07:19:09 RepetierServer dhcpcd[614]: wlan0: IAID eb:a7:26:37
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) started...
Aug 6 07:19:09 RepetierServer avahi-daemon[399]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.10.10.1.
Aug 6 07:19:09 RepetierServer avahi-daemon[399]: New relevant interface wlan0.IPv4 for mDNS.
Aug 6 07:19:09 RepetierServer avahi-daemon[399]: Registering new address record for 10.10.10.1 on wlan0.IPv4.
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol tcp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol udp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol tcp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert INPUT --in-interface wlan0 --protocol udp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --in-interface wlan0 --jump REJECT
Aug 6 07:19:09 RepetierServer dhcpcd[614]: wlan0: carrier lost
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --out-interface wlan0 --jump REJECT
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --in-interface wlan0 --out-interface wlan0 --jump ACCEPT
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --source 10.10.10.0/255.255.255.0 --in-interface wlan0 --j
ump ACCEPT
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --insert FORWARD --destination 10.10.10.0/255.255.255.0 --out-interface wla
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: ip-config -> ip-check (reason 'none') [70 80 0]
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete.
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: ip-check -> secondaries (reason 'none') [80 90 0]
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: secondaries -> activated (reason 'none') [90 100 0]
Aug 6 07:19:09 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) successful, device activated.
Aug 6 07:19:09 RepetierServer nm-dispatcher: Dispatching action 'up' for wlan0
Aug 6 07:19:10 RepetierServer dhcpcd[614]: wlan0: soliciting an IPv6 router
Aug 6 07:19:10 RepetierServer dhcpcd[614]: wlan0: rebinding lease of 192.168.2.107
Aug 6 07:19:11 RepetierServer ntpd[656]: Listen normally on 16 wlan0 10.10.10.1 UDP 123
Aug 6 07:19:14 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
Aug 6 07:19:14 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) started...
Aug 6 07:19:14 RepetierServer NetworkManager[2934]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Aug 6 07:19:15 RepetierServer dhcpcd[614]: wlan0: probing for an IPv4LL address
Aug 6 07:19:15 RepetierServer dhcpcd[614]: wlan0: DHCP lease expired
Aug 6 07:19:16 RepetierServer dhcpcd[614]: wlan0: soliciting a DHCP lease
Aug 6 07:19:20 RepetierServer dhcpcd[614]: wlan0: using IPv4LL address 169.254.115.215
Aug 6 07:19:20 RepetierServer avahi-daemon[399]: Registering new address record for 169.254.115.215 on wlan0.IPv4.
Aug 6 07:19:20 RepetierServer dhcpcd[614]: wlan0: adding route to 169.254.0.0/16
Aug 6 07:19:22 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: activated -> deactivating (reason 'user-requested') [100 110 39]
Aug 6 07:19:22 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: deactivating -> disconnected (reason 'user-requested') [110 30 39]
Aug 6 07:19:22 RepetierServer NetworkManager[2934]: <info> (wlan0): deactivating device (reason 'user-requested') [39]
Aug 6 07:19:23 RepetierServer dhcpcd[614]: wlan0: carrier lost
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Interface wlan0.IPv4 no longer relevant for mDNS.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.10.10.1.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Withdrawing address record for 169.254.115.215 on wlan0.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Withdrawing address record for 10.10.10.1 on wlan0.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.115.215.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: New relevant interface wlan0.IPv4 for mDNS.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Registering new address record for 169.254.115.215 on wlan0.IPv4.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Registering new address record for 10.10.10.1 on wlan0.IPv4.
Aug 6 07:19:23 RepetierServer avahi-daemon[399]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.115.215.
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> (wlan0): supplicant interface state: completed -> disconnected
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> (wlan0): supplicant interface state: disconnected -> disabled
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> (wlan0): supplicant interface state: disabled -> disconnected
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --destination 10.10.10.0/255.255.255.0 --out-interface wla
Aug 6 07:19:23 RepetierServer nm-dispatcher: Dispatching action 'down' for wlan0
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --source 10.10.10.0/255.255.255.0 --in-interface wlan0 --j
ump ACCEPT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --in-interface wlan0 --out-interface wlan0 --jump ACCEPT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --out-interface wlan0 --jump REJECT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete FORWARD --in-interface wlan0 --jump REJECT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol udp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol tcp --destination-port 67 --
jump ACCEPT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol udp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> Executing: /sbin/iptables --table filter --delete INPUT --in-interface wlan0 --protocol tcp --destination-port 53 --
jump ACCEPT
Aug 6 07:19:23 RepetierServer NetworkManager[2934]: <info> (wlan0): device state change: disconnected -> unmanaged (reason 'removed') [30 10 36]
Aug 6 07:19:24 RepetierServer kernel: [64170.888960] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Aug 6 07:19:24 RepetierServer dhcpcd[614]: wlan0: deleting route to 169.254.0.0/16
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> devices added (path: /sys/devices/platform/soc/3f300000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0, iface: w
lan0)
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> device added (path: /sys/devices/platform/soc/3f300000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0, iface: wl
an0): no ifupdown configuration found.
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): using nl80211 for WiFi device control
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): driver supports Access Point (AP) mode
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): new 802.11 WiFi device (driver: 'brcmfmac' ifindex: 3)
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): exported as /org/freedesktop/NetworkManager/Devices/2
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): preparing device
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0) supports 5 scan SSIDs
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: starting -> ready
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42]
Aug 6 07:19:24 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: ready -> disconnected
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: disconnected -> inactive
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0) starting connection 'thor'
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0/wireless): connection 'thor' has security, and secrets exist. No new secrets needed.
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Aug 6 07:19:25 RepetierServer wpa_supplicant[595]: wlan0: Trying to associate with 08:60:6e:cb:03:70 (SSID='thor' freq=2452 MHz)
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: inactive -> associating
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): disconnecting for new activation request.
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: config -> deactivating (reason 'none') [50 110 0]
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: deactivating -> disconnected (reason 'none') [110 30 0]
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): deactivating device (reason 'none') [0]
Aug 6 07:19:25 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-DISCONNECTED bssid=08:60:6e:cb:03:70 reason=3 locally_generated=1
Aug 6 07:19:25 RepetierServer nm-dispatcher: Dispatching action 'down' for wlan0
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: associating -> disconnected
Aug 6 07:19:25 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: disconnected -> associating
Aug 6 07:19:26 RepetierServer ntpd[656]: Deleting interface #16 wlan0, 10.10.10.1#123, interface stats: received=0, sent=0, dropped=0, active_time=15 secs
Aug 6 07:19:33 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=16
Aug 6 07:19:33 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: associating -> disconnected
Aug 6 07:19:33 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: disconnected -> scanning
Aug 6 07:19:34 RepetierServer wpa_supplicant[595]: wlan0: Trying to associate with 08:60:6e:cb:03:70 (SSID='thor' freq=2452 MHz)
Aug 6 07:19:34 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: scanning -> associating
Aug 6 07:19:39 RepetierServer wpa_supplicant[595]: wlan0: Associated with 08:60:6e:cb:03:70
Aug 6 07:19:39 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: associating -> associated
Aug 6 07:19:40 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: associated -> 4-way handshake
Aug 6 07:19:44 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Aug 6 07:19:50 RepetierServer wpa_supplicant[595]: wlan0: Authentication with 08:60:6e:cb:03:70 timed out.
Aug 6 07:19:50 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-DISCONNECTED bssid=08:60:6e:cb:03:70 reason=3 locally_generated=1
Aug 6 07:19:50 RepetierServer wpa_supplicant[595]: wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Aug 6 07:19:50 RepetierServer wpa_supplicant[595]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="thor" auth_failures=1 duration=10 reason=WRONG_KEY
Aug 6 07:19:50 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: 4-way handshake -> disconnected
Aug 6 07:19:50 RepetierServer NetworkManager[31081]: <info> Activation (wlan0/wireless): disconnected during association, asking for new key.
Aug 6 07:19:50 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: config -> need-auth (reason 'supplicant-disconnect') [50 60 8]
Aug 6 07:19:50 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: need-auth -> failed (reason 'no-secrets') [60 120 7]
Aug 6 07:19:50 RepetierServer NetworkManager[31081]: <warn> Activation (wlan0) failed for connection 'thor'
Aug 6 07:19:50 RepetierServer NetworkManager[31081]: <info> (wlan0): device state change: failed -> disconnected (reason 'none') [120 30 0]
Aug 6 07:19:50 RepetierServer NetworkManager[31081]: <info> (wlan0): deactivating device (reason 'none') [0]
Aug 6 07:19:51 RepetierServer wpa_supplicant[595]: wlan0: Failed to initiate sched scan
Aug 6 07:19:51 RepetierServer NetworkManager[31081]: <info> (wlan0): supplicant interface state: disconnected -> inactive
Aug 6 07:19:54 RepetierServer wpa_supplicant[595]: wlan0: Failed to initiate sched scan
Thx
Mike
jump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
ump ACCEPT
ump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
ump ACCEPT
ump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
jump ACCEPT
lan0)
Any linux guru understands this behaviour?
