Extruder retracts the filament out of hotend
I have been printing for couple of days now and there was too much filament stripping. So after doing all the usual steps, I decreased the feedrate to crazy low speeds (0.1). When I started printing with those speeds, the extruder will retract the filament so much that it will come out of cold end. It does it every time it has to retract while printing. I have tried re uploading the firmware, restoring all the settings, using different slicers (sli3cr and curaengine), But the problem won't go away
Retraction length is 2mm and speed is 25. Current Feed rate is 1mm/s
