0.60.x(4) Installer
edited July 2015 in Bug Reports
Hi gentleman.
I apologize for my not native English.
A) I could see that  using autoupdate procedure wont work well (tested from .3 to .4) ) I had to d/l the file and use the exe file instead.
In any case if you press the autoupdate button abd set pause or (circling) run, for  both the situations,  the label is always : "procedure started" (should be stopped/paused and started)
B) the server installer won't detect correct path (the client installer is working great) if you have installed the server in a different path than the default. - In my case is D:\Installation_repetierserver. but installer wont see it and try to set it up on c:\programs(x86)  folder
..and (lol) on the 1.5.4 client there is still the old .3 server packed ;)
have great days and thank you for great work.
ciao
Andrea
  • In deed the download manager did not see our updated link and still provided 0.60.3 as latest:-( Fixed.
    Autoupdate also had a wrong link in download script, also fixed now.
    B) Will check that, but it is a installer generated by CMake so nothing directly set. Hope there is a simple way to make it remember latest path otherwise autoupdate which is silent will use default path.
