temperature curve , output bed
Hello
I'm new to 3d printing, got a airwolf aw3d xl yesterday, under the Temperature curve Tab,  there are 2 graphs, output extruder and output bed, when I heat up both of them, nothing appears on the output bed graph, only on the extruder graph. both heat up.
Jean-Pierre
  • any suggestions ? Do you guys know from where the output power is taken from ?
    JP
  • Output bed is taken from M105 response @B:255 for example. If the used firmware does not contain this you will see no output as the host does not know how much is used.
