how repetier works internally.
with a loaded gcode file - if i start a print it appears that repetier uploads a small section of code at a time to the printer - shown in red on the manual control page. If I change some code that has not been uploaded will that change what is eventually sent to the printer???
IE, is the gcode shown what is actually being sent to printer in real time or is it just a copy.
  • When you click print a send buffer is filles with command s to be send. Deleting the gcode in preview will not change that. Also later changes have no effect.
