How to finish filament change by using Communication command
Dear Repetier Engineer
I was tryting to use "M600" command to change the filament, it works.  Is it possible to send another command like "M??" to continue to printer? Thanks.
  • No. M600 blocks communication until it is finished. If you want tocontrol from host/server use a pause instead and do filament change action on host/server side.
  • OK, thanks for your quick reply. :)
