plugged extruder tip
how to use the Repetier-Host panel to extrude filament without using an object file.
  • Heat extruder and then hit extrude button. Or use the matching gcode commands to send commands manually (easy mode off).
  • Is extrude button in host ver 2.0.2 the manual control screen "button" pad on the right with the extruder outline in the center? The pad to the right of the Z control? And, where do I find the gcode commands to send manually? (I'm a noobie, but I'm sure you've guessed that.)
  • Here you find description of gcode commands:
    http://www.reprap.org/wiki/Gcodes
    For extrusion G1, G92 are th emost relevant.
