g32 entry in doubt
When I run g32 into my mini Kossell (kit build), it alters the values in 'Z max length', but doesn't touch 'x' or 'y' max lengths when I review the eeprom settings. Is this correct behavior? Should I alter the other values as well? Especially since I believe that the 'tower endstop offsets' are set to correct max length anomolies.
  • x and y length are for defining valid bed outer square together with x,y min. G32 is only correcting z direction so it is ok that it does not change them. So for 200 radius
    x,y min = -100, x,y length = 200
