Preview Editor issue
if I add Start GCode G92 Z200 Repetier Host shows the modell in the preview in Z -200:
In my eyes this is a bug. I've the same issue in Repetier Server. In Slic3r it doesn't show it like this.
Your print starts for example at Z=0.2 which is now displayed as coordinate Z= -199.8
from my point of view absolute correct.
so what´s the reason for Start G-Code G92 Z200?
The reason to send a G92 Z200 is that I lift Z to 200 after printing. As long, as no reset of the printer is needed everything is fine without G92, because M114 is Z200. But if the printer does a reset Z is 0 - which isn't the truth.
Because of this my idea was to tell the printer Z is already on 200. After this Z is going down to 0.2.
I know the simplest solution would be to home all axis including Z, but can't home Z before printing because I'm using a Z-probe and see no chance at the moment to mount a hardware endstop at Z-max.
greets from Solingen.
