Multiple compile errors
Hello
Im trying to compile my newly downloaded firmware but get a lot of errors so it can not complie. Any ideas what to do?
Arduino:1.8.1 (Mac OS X), Kort:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch/HAL.h:83:0,
                 from sketch/Repetier.h:539,
                 from sketch/HAL.cpp:1:
sketch/HAL.cpp: In function 'void __vector_22()':
fastio.h:29: error: 'DIOORIG_FAN2_PIN_WPORT' was not declared in this scope
 #define  _WRITE(IO, v)   do { if (v) {DIO ##  IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ##  IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
sketch/fastio.h:48:25: note: in expansion of macro '_WRITE'
 #define  WRITE(IO, v)   _WRITE(IO, v)
sketch/HAL.cpp:847:91: note: in expansion of macro 'WRITE'
         if((pwm_pos_set[PWM_BOARD_FAN] = (pwm_pos[PWM_BOARD_FAN] & COOLER_PWM_MASK)) > 0) WRITE(FAN_BOARD_PIN,1);
fastio.h:29: error: 'DIOORIG_FAN2_PIN_PIN' was not declared in this scope
sketch/fastio.h:17:30: note: in definition of macro 'MASK'
  #define  MASK(PIN)    (1 << PIN)
sketch/HAL.cpp:947:108: note: in expansion of macro 'WRITE'
     if(pwm_pos_set[PWM_BOARD_FAN] == pwm_count_cooler && pwm_pos_set[NUM_EXTRUDER + 1] != COOLER_PWM_MASK) WRITE(FAN_BOARD_PIN,0);
Multiple libraries were found for "SPI.h"
 Använd: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
Oanvänd: /Users/stefan/Documents/Arduino/libraries/rfid_buzzer
exit status 1
  • edited March 15
    seems you have not defined pin numbers for all fans ( look at config.h)
  • You are ung fan2 but your board definition does not have a default pin for that, so you need to explicitly say the pin number.
  • Great! Thank you very much for the quick response. Now it compiles with out an error so I'll test it in the printer tomorrow.
