ARC does not work
Hello at all,
I'm using repetier 0.92 to run a cnc mill.
I'm using Repetier host to enter gcode manually to the mill.
Using Ramps 1.4..
I made some test runs so far, but couldn't  drive a full circle like:
G03 X36.5 Y50 I0 J16.5 (Generated by HeeksCNC)
All I get is one have of the circle an then X and Y are going to Position 1000000;1000000 or even higher ...
I made all kind of changes (decreased Microstepping to 1/4, decreased all speeds and so on).
No changes for the movement to infinity after one have of the circle.
Can someone help me
please ?
Regards
Jens
  • In the meanwhile I had a closer look to the gcode.
    I imported it to Freecad, to visualize the moves without heeksCNC.
    Than I exported it to gcode, with the folloing efect:
    The parameter exchanged places.
    I used the new  code torun the mill that worked like a charme. The code I got from HeeksCNC wors the way it did yesterday.
    So far I have asolution, even if I dont know why. Topic solved.
    Jens
