X_MAX Problem
My printer does not move more than 200mm on the x axis. I set X_MAX_LENGTH = 320
  • Please check eeprom settings if there x length is also 320. I guess not.
  • Thank you so much. If the eProm setting is set to 320, the problem is corrected
