Homing when already home
I have an issue with Repetier host where if the carriage is already homed and a G28 is sent (limit switches are triggered), an error is thrown saying homing failed and a pause has been requested.   Is there a setting to make the carriage move enough to untoggle limit switches if they are toggled?
Delta, using MAX endstops.
  • Sounds like repetier firmware. On deltas you shoudl always move away from endstops after homing. In config tool set "Endstop distance after homing" z value to 10 or more. Reduce z length the same amount. You can not print at the top anyway as any move triggers endstop. Then rehoming is also no issue any more.
