Extruder going to fast
I've recently installed the new repeiter, but my extruder seems to be going way too fast. My EEPROM, Slicer and Printer settings are the same before the update.
  • Sure steps per mm is still the same? It's the only value changing speed for the same gcode.
  • Maybe try to clear the eeprom.
    After I upgraded from 0.91 to 0.92 my extruded ran at half speed, for the same step/mm. After clearing eeprom and setting all the values again it worked correctly.
