Random firmware resets
I am using 0.92.8 version of firmware.
I love the features and I am generaly satisfied with the SW.
However, lately I started to experience a strange problem.
I have direct serial connection to my Melzi board from Banana Pi. This works no problem. I printed hundreds of hours worth of prints.
Lately, however, I start to have failures - Octoprint complains about "Unhandled firmware exception".
So, I checked what's going on - I am sending Gcode to the board as usual and on random places all of a sudden the board resets.
I can see the log - sent command and instead of OK, I can see the repetier FW initialization log.
And, as soon as the timeout hits, Octoprint starts to resend the command, but this is unsuccessfull, of course, as Repetier is expecting command number 1 and I'm sending command number 3000...
I have not seen a common pattern  for now - even when I try to re-print the same thing, usualy all prints OK.
Once this happened twice in a row.
I checked all the power connections for the board (powered by the printer, not by USB or anything).
But it's very difficult for me to identify possible short-term power outage :(
Any hints/tips from someone who experienced similar behaviour?
  • Today it happened again, this is the serial log from the moment:
    Recv: ok 13027
    Send: N13029 G1 X50.058 Y93.867 E4.10485*108
    Recv: ok 13028
    Send: N13030 G1 X50.058 Y94.733 E4.15007*102
    Recv: start
    Recv: Info:Autoleveling enabled
    Recv: Transformation matrix: 1.000000 -0.000000 -0.000257 0.000000 1.000000 -0.000632 0.000257 0.000632 1.000000
    Recv: Free RAM:12597
    Recv: SelectExtruder:0
    Recv: FlowMultiply:100
  • And right after restart, while only heating the extruder and bed:
    Recv: T:232.80 /245 B:84.55 /94 B@:255 @:230
    Recv: T:235.40 /245 B:84.55 /94 B@:255 @:230
    Recv: start
    Recv: SD init fail
    Changing monitoring state from 'Operational' to 'Closed'
    Connecting to: /dev/ttyS3
    Changing monitoring state from 'Offline' to 'Opening serial port'
    Connected to: Serial<id=0xa08ebd30, open=True>(port='/dev/ttyS3', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=30.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
    Changing monitoring state from 'Opening serial port' to 'Connecting'
    Send: N0 M110*35
    Recv: ok
    Changing monitoring state from 'Connecting' to 'Operational'
    Send: N1 M115*39
    Recv: ok 1
    Recv: FIRMWARE_NAME:Repetier_0.92.8 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    Recv: Printed filament:587.72m Printing time:6 days 7 hours 22 min
    Recv: PrinterMode:FFF
    Send: N2 M105*37
    Recv: ok 2
