Servo on Azteeg X3 Pro
Hi
I try to use a servo for Z-Probing on my Azteeg X3 Pro. Without success until now. The Servo is simply shaking in both directions from time to time.
As power source for the Servo I have tried three things: A Batterypack and two different AC/DC converters with 5V/1A and 5V/2A output. (Servo needs 5V and about 500mA)
I tried D12 and D47 to connect the Servo to the board.
And I tried two different Servos.
At the moment I dont know what to do/try next, so any tipps are welcome.
Here is my configuration.h:
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   generator: http://www.repetier.com/firmware/v092/
   as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 35
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN 6
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#undef Y_MIN_PIN
#define Y_MIN_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 1
#define DRIVE_SYSTEM 1
#define XAXIS_STEPS_PER_MM 320
#define YAXIS_STEPS_PER_MM 320
#define ZAXIS_STEPS_PER_MM 100
#define PDM_FOR_EXTRUDER 1
#define PDM_FOR_COOLER 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define SHARED_EXTRUDER_HEATER 1
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 187
#define EXT0_TEMPSENSOR_PIN 13
#define EXT0_HEATER_PIN 9
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 250
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN 4
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 100
#define EXT1_TEMPSENSOR_TYPE 8
#define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT1_HEATER_PIN HEATER_0_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_EXTRUDER_COOLER_PIN 4
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_PIN 14
#define HEATED_BED_HEATER_PIN 8
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 290
#define MAX_DEFECT_TEMPERATURE 300
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 5
#define ENDSTOP_Y_BACK_ON_HOME 5
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 300
#define Y_MAX_LENGTH 300
#define Z_MAX_LENGTH 280
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_CORRECTION_POINTS 6
#define DISTORTION_PERMANENT 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 290
#define DISTORTION_YMAX 290
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 50
#define HOMING_FEEDRATE_X 60
#define HOMING_FEEDRATE_Y 60
#define HOMING_FEEDRATE_Z 25
#define HOMING_ORDER HOME_ORDER_YXZ
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 1
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E4_STEP_PIN
#define Z2_DIR_PIN    ORIG_E4_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E4_ENABLE_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 0
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 1
#define SERVO0_PIN 12
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS  1500
#define UI_SERVO_CONTROL 1
        #define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PIN 14
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 15
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 20
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 150
#define Z_PROBE_Y1 10
#define Z_PROBE_X2 290
#define Z_PROBE_Y2 290
#define Z_PROBE_X3 10
#define Z_PROBE_Y3 290
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 21
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 0
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "H-Printer"
#define UI_PRINTER_COMPANY ""
#define UI_ANIMATION 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 1
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN 5
#define UI_START_SCREEN_DELAY 3000
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 70
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   210
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 80
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_EXTRUDER_TEMP   150
#define UI_SET_MAX_EXTRUDER_TEMP   290
#define NUM_MOTOR_DRIVERS 0
#endif
  • Make sure to use the right numbers
    Your config has P0 as ID. If pulse time is outside allowed range it might do unexpected things. Normally you should also use R parameter as timeout to stop sending signals after some time. While powered servo will jitter, so nothing you want. But it should jitter around set position.
  • Made rigth now some new tests.
    When I turn the printer on or connect the servo when the printer is already turnd on, the servo moves to the right most position and it jitters.
    When I send the following command : M340 P0 S500 R500 (tried also other S values) nothing happens. No movement to new position and it still jitter.
  • Can you connect a led instead of servo? With R500 it should disable servo after 500ms. With led + resistor to signal pin->gnd you should see led intensity vary depending on S and get it disabled with S0 or after R ms. Maybe you are simply using wrong pin. If you have a logic analyser it would help even more, but a led should do for testing if pin is correct.
  • I have the same problem. When i use over the arduino display it goes. When i sending the command over repetier Host ihr pronterfase nothing Happen. I dont know why?!
  • Ok, I'm back.
    Now that I have found a logic analyzer I can use, I will make some new tests.
    Will report the results as soon as I have some.
  • After verry much measurement and reading of technical data of the Azteeg X3 Pro and the servo I use, here are my results:
    Looks like I had problems with the external 5V Servopower. I dont really know what the problem was, With the logic analyzer I found that the positioning signal at the servo was verry bad. I stopped serching the problem after I found in technical data the following values: The Azteeg X3 Pro can give 1A at 5V, the micro servo I use needs about 500-600mA at 5V. So I changed 5V servopower from external to Azteeg on board. And the result is that the positioning signal at the servo looks great and positioning the servo is working as it should. :D
  • Great the the Azteeg has so much power. Most have 500mA from the Arduino and that is needed for lcd etc.
  • I've had this happen before. It looks like switching power supplies worked for OP, but if anyone else has this issue, try this:
    #define Z_PROBE_START_SCRIPT "M340 P0 S2290\nG4 P2000\nM340 P0 S0"
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S800\nG4 P2000\nM340 P0 S0"
    This waits 2 seconds (long enough for servo to move) and then stops sending signal.
    The only time this didn't work was on a ultimaker 1.5.7. Somehow on that board my servo was affected by hot end PWM, so the hot end had to be off for the servo to stop twitching,
  • Isn't this the same as "M340 P0 S2290 R2000" for start script and "M340 P0 S800 R2000" for finished script?
  • Not exactly. R2000 will disable servo after 2 seconds, but will directly continue with the remaining code. G4 will block everything following up for 2 seconds and also wait for all moves to end.
