Adding new printer doesn't add/detect extruder
I noticed that when adding a new printer the wizard does not detect that there is an extruder in the firmware.
IT properly detects the hotbed but not the extruder and I have to manually add it and fill in the details.
As that data is available from the EEPROM shouldn't it be able to detect it and add it automatically?
Thanks!
  • Extruder count is taken from M115 result using the EXTRUDER_COUNT:2 part. What firmware did you use and what did it return on M115?
