Repetier-Firmware version 0.92.9 and PiBot v2 Controller
Is it possible to get the latest Repetier firmware to work on the PiBot v2.0 Controller and PiBot LCD?  I uploaded the firmware from the configurator but get no LCD display once it has been loaded.  I have chosen the correct PiBot 20x4 LCD display from the Repetier configurator.  Also the Repetier Host connects but does not successfully transmit commands to the PiBot controller.
When I revert back to the PiBot firmware everything is fine.  Any ideas?
  • Pi bot is also using repetier if I'm correct. So do they use the same pins in pins.h and ui.h lcd section for the pi bot 2? If they have made adjustments let me know and I add them to official version as well.
