Repetier 0.92.9 printing mid air
edited May 2016 in General
hi all, i am having a really weird issue with repetier firmware:
basically, when printing, the first layer is printed at about 2mm (i'm guessing) from the bed, HOWEVER, if i do a "dry run", the nozzle has the correct distance.
i'm going insane trying to figure this out. i don't understand why the dry run works perfectly and the actual print is bugged.
btw, my board is ramps 1.4, printer is i3 acrylic.
i can provide my configuration.h if needed, however i don't think that's wrong cause as i said, the dry run works correctly and i have not set any extruder offset...
forgot to mention that i'm using repetierhost 1.6.1 and slic3r
...and compiling with Arduino 1.6.9
  • nvm, fixed it. redid the configuration from scratch, probably it was some parameter about z-probe or bed correction that slipped the first time
    i don't think that those should be enabled by default tho
