your printer has asked for a break
repetier host displayed after M321 and G28
  • Please check the log. I guess G28 failed switching endstops as expected. Maybe you are not moving enough away from endstops.
  • hello
    if I'm already home the G28 fails
  • What does M119 say after homing. All endstops should be low since you are supposed to go down after hitting them.
    #define ENDSTOP_Z_BACK_ON_HOME 30
    That gives also room for selecting excentirc extruders which seems your main problem and I think, also I mention this a few times, you still have not set this value.
