Output Extruder
Hello;
I am new here. Just getting into hobby.
The basic question is What does the Output Extruder window on the Temperature Curve mean? The rate has not reached greater than the 50 line. It has gradually reach lower and lower. I just discovered the nozzle is plugged.
I would like an over view of Output Extruder. I am running Host V1.0.6.
Thank You for your time.
  • That is the power send to extruder heater in percent. You can define in firmware how much power should be used. Especially pid controller will regulate it to a value needed, while on startup you might see 100%. During print you do not want constant 100% as this would be working on the limit.
  • Thank You for the perfect answer. Finely got every thing set now; great 0.10mm prints.
