UI Actions for CASE LIGHTS and Powersupply
Hi ,
i try to use  UI Menue for switching Power Supply and Case Lights .
I can switch on but not off.Also Status on Display does not change from off to On
When i use G-Code via Repetier host  m355 S1/S0 for Lights and M80  M81  for Powersupply works
FW Repetier 0.92.8 from today
Thanks for your help,
RAyWB
  • Seems to be my mistake. As i work without shield  i used PWM PINS after a look at the TOGGLE function i changed to normal digital I/O Pin . Now it works as it should.
    RAyWB
