Can i use a Foscam?
Hi All
Was going through the webcam setup, but now I am stuck, as I see no way to enter a username/password...
I'm guessing the repetier server software only supports a camera connected locally via USB?
If not, how do i connect to a Foscam that requires a login?
  • It also supports ip webcams. You need to find out what the right url is. Easiest way is to login in the web frontend of your webcam and rightclick on the video image to check the element. Then in element debugger you see the url of it. My ip cam had the password/login in the link so you only needed to copy that link. Same trick for static image in web frontend of webcam.
