gen4 electroncis
trying to connect the 3d printer white ant to repetier but cant.  white ant uses gen4 electronics.  Any help?
  • Didn't even know there is a working gen 4 available. You could try to add a new section in pins.h with pinout for gen4 if you find it. For most boards today it is only a question of setting the right pins to get new boards working.
  • Patrick over at build your cnc says it is gen4 electronics,  he is not very helpful when setting it up to work with anything other than replicator g.
