start repetier service dosent work for me
HI there maybe someone could help me
i was installing repetier server then a after a day i was trying to start repetier service by the following instruction
and i get bash: repetier : command not found .
i was rooting to the specific folder when i can find repetier service files which is in etc/init.d/repetier server  and the files is there and the instillation for repetier was ok
so what am i doing wrong
thank you
nothing seems to work any idea
  • It should start after reboot automatically.
    To start manually you send
    sudo /etc/init.d/RepetierServer start
    maybe you forgot sudo? Without it won't start.
