The temperature does not rise
I am running the command of M109 S180
After 130C temperature increase is slowing down.
and it remains constant at 150 ° C.
180C 'had not reached
Thank you
  • Check in host/server the output power. I guess you have limited max. PWM to a value < 255 and this prevents the power needed to heat it further.
  • How do I upgrade power limit?
  • power value 255.
      What else could be the problem?
  • 12 V 20.8A güç kaynağı
    fanı çalıştıran
    Sıcaklık hızla düşüyor
    fan kapalı olduğunda
    sıcaklık istenilen değere ulaştığında
    fanı çalıştıran
  • 12 V 20.8A power supply
    the fan is running,
    Temperature falling rapidly
    When the fan off by
    temperature reaches the desired value
  • I wrote it wrong
  • There are 2 max pwm values. If you really see 100% in host temperature then your heater is too weak. Fan cools more then you can heat. Normally this is not the case for full metal hotends that need extra cooling and it is the pwm. Also check eeprom values.
