Ramps endswitch doesnt work but now RADD also
Well in the proces of checking my endstop settings see my other post, I lost one rampsboard
due to replacing a broken  stepper driver in the wrong position.
My wife saved me from throwing the printer out of the window. I replaced the RAMPS with a RADD and last night, after creating the.INO
with the Repetier 0.92 setup pages, I programmed the Arduino DUE. All
went well no errors.
After home click the steppers were running, temp
ok, BUT endstops had no influence what so ever so the steppers did not
home. Repetier host timed out and stopped the steppers. Tested with M119
swiched by hand and that looks fine, open when pushed. So now I am kind
of lost here.
I must be doing somthing wrong (always check endstops is on). I added the switchpart of the config.h
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
