E3d v6 upgrade problems
I just installed an E3d v6 on my Solidoodle 3. It seemed like everything was going right until I connected to Repetier and tried to heat the extruder. It would work briefly then stop. It all stopped working at once (X,Y and Z movement, extruder function etc..) When I press disconnect and then connect again, it all works briefly then stops working again. Could it be my Repetier settings?
  • What firmware and what does th elog say on stop? Could be a problem with the thermistor playing cracy causing firmware to stop.
