Heated Bed disables after connecting server
I'm still working on updating my Firmware, now mostly running but run in a strange problem. When I upload the firmware, the heated bed works normal, but as soon as I connect with Repetier Server to the printer, the display of the heated bed temp on the display changes to zero, and I can't turn the heat on anymore. Even when I disconnect the server and reset the printer there is no heated bed. When I upload the firmware again the heated bed is back. what can this be?
This is my configuration.h
Thanks,
along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 1.0.4dev
as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 80
#include "pins.h"
#define HOST_RESCUE 1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
#undef X_MIN_PIN
#define X_MIN_PIN -1
#undef Y_MIN_PIN
#define Y_MIN_PIN -1
#undef Y_STEP_PIN
#define Y_STEP_PIN ORIG_E2_STEP_PIN
#undef Y_DIR_PIN
#define Y_DIR_PIN ORIG_E2_DIR_PIN
#undef Y_ENABLE_PIN
#define Y_ENABLE_PIN ORIG_E2_ENABLE_PIN
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define ZAXIS_STEPS_PER_MM 100
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_START_COMMANDS "M25"
#define PAUSE_END_COMMANDS "M24"
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 187
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_REHOME 2
#define FILAMENTCHANGE_LONGRETRACT 250
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define TEMP_GAIN 1
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 310
#define MAX_DEFECT_TEMPERATURE 325
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 10
#define ENDSTOP_Y_BACK_ON_HOME 10
#define ENDSTOP_Z_BACK_ON_HOME 10
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 1
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 1
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 448
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 0
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 355 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 150
#define ROD_RADIUS 184.96
#define PRINTER_RADIUS 184.96
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 250
#define MAX_FEEDRATE_Y 250
#define MAX_FEEDRATE_Z 250
#define HOMING_FEEDRATE_X 50
#define HOMING_FEEDRATE_Y 50
#define HOMING_FEEDRATE_Z 50
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define Z4_STEP_PIN ORIG_E3_STEP_PIN
#define Z4_DIR_PIN ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define STARTUP_GCODE ";Home G28 G1 X0 Y-100 Z030 F5000 ;Prime the extruder G92 E0 G1 F200 E30 G92 E0"
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 7
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 1.14
#define Z_PROBE_DELAY 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 100
#define Z_PROBE_X2 60
#define Z_PROBE_Y2 -90
#define Z_PROBE_X3 -60
#define Z_PROBE_Y3 -90
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 2
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 1
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define LANGUAGE_RU_ACTIVE 0
#define UI_PRINTER_NAME "LoiLand 3D Printer"
#define UI_PRINTER_COMPANY "LoiLand Design Comp"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN ORIG_FAN2_PIN
#define UI_SET_MAX_HEATED_BED_TEMP 130
#define UI_SET_MIN_EXTRUDER_TEMP 150
#define UI_SET_MAX_EXTRUDER_TEMP 315
#define NUM_MOTOR_DRIVERS 0
#endif
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"bluetoothSerial": -1,
"bluetoothBaudrate": 115200,
"xStepsPerMM": 100,
"yStepsPerMM": 100,
"zStepsPerMM": 100,
"xInvert": "1",
"x2Invert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": "1",
"y2Invert": 0,
"yInvertEnable": 0,
"zInvert": "1",
"z2Invert": 0,
"z3Invert": 0,
"z4Invert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 1,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 1,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "1",
"invertEnable": "0",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 187,
"coolerPin": -1,
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 190
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 0,
"yMinEndstop": 0,
"zMinEndstop": 1,
"xMaxEndstop": 2,
"yMaxEndstop": 2,
"zMaxEndstop": 2,
"x2MinEndstop": 0,
"y2MinEndstop": 0,
"x2MaxEndstop": 0,
"y2MaxEndstop": 0,
"motherboard": 80,
"driveSystem": 3,
"xMaxSpeed": 250,
"xHomingSpeed": 50,
"xTravelAcceleration": 1000,
"xPrintAcceleration": 1000,
"yMaxSpeed": 250,
"yHomingSpeed": 50,
"yTravelAcceleration": 1000,
"yPrintAcceleration": 1000,
"zMaxSpeed": 250,
"zHomingSpeed": 50,
"zTravelAcceleration": 1000,
"zPrintAcceleration": 1000,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "0",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 360,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 200,
"yLength": 200,
"zLength": 448,
"alwaysCheckEndstops": "1",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": 1,
"xEndstopBack": 10,
"yEndstopBack": 10,
"zEndstopBack": 10,
"deltaDiagonalRod": 355,
"deltaHorizontalRadius": 184.96,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 150,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 20,
"stepperHighDelay": 0,
"directionDelay": 0,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "1",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "0",
"mirrorZMotor": {
"mirrorZ3": "0",
"mirrorZ3Motor": {
"mirrorZ4": "0",
"mirrorZ4Motor": {
"name": "Extruder 3",
"step": "ORIG_E3_STEP_PIN",
"dir": "ORIG_E3_DIR_PIN",
"dittoPrinting": "0",
"featureServos": "0",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "1",
"hasHeatedBed": "1",
"enableZProbing": "1",
"extrudeMaxLength": 160,
"featureController": 2,
"uiPrinterName": "LoiLand 3D Printer",
"uiPrinterCompany": "LoiLand Design Comp",
"uiPagesDuration": 4000,
"uiHeadline": "",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 10,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "0",
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 130,
"uiMinEtxruderTemp": 150,
"uiMaxExtruderTemp": 315,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 1,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 1,
"bedPreheat": 55,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": "ORIG_FAN2_PIN",
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 310,
"minDefectTemp": -10,
"maxDefectTemp": 325,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"featureFan2Control": "0",
"fan2Pin": "ORIG_FAN2_PIN",
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 255,
"fanThermoMinTemp": 45,
"fanThermoMaxTemp": 60,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 1,
"scalePidToMax": "1",
"zProbeBedDistance": 10,
"zProbeDisableHeaters": "0",
"zProbePullup": "0",
"zProbeOnHigh": "0",
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 7,
"zProbeXYSpeed": 150,
"zProbeHeight": 1.14,
"zProbeStartScript": "",
"zProbeFinishedScript": "",
"featureAutolevel": "1",
"zProbeX1": 0,
"zProbeY1": 100,
"zProbeX2": 60,
"zProbeY2": -90,
"zProbeX3": -60,
"zProbeY3": -90,
"zProbeSwitchingDistance": 1,
"zProbeRepetitions": 2,
"zProbeMedian": "0",
"zProbeEveryPoint": "",
"sdSupport": "0",
"sdCardDetectPin": -1,
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": -1,
"yMinPin": -1,
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": "ORIG_X_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_Z_MAX_PIN",
"x2MinPin": -1,
"y2MinPin": -1,
"x2MaxPin": -1,
"y2MaxPin": -1,
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"pdmForHeater": "0",
"pdmForCooler": "0",
"psOn": -1,
"mixingExtruder": "0",
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "M25",
"pauseEndCommands": "M24",
"distortionCorrection": "1",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"featureRetraction": "1",
"autoretractEnabled": "0",
"retractionLength": 3,
"retractionLongLength": 13,
"retractionSpeed": 40,
"retractionZLift": 0,
"retractionUndoSpeed": 20,
"filamentChangeXPos": 0,
"filamentChangeYPos": 0,
"filamentChangeZAdd": 2,
"filamentChangeRehome": 2,
"filamentChangeLongRetract": 250,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "1",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 220,
"jamSlowdownSteps": 320,
"jamSlowdownTo": 70,
"jamErrorSteps": 500,
"jamMinSteps": 10,
"jamAction": 1,
"jamMethod": 1,
"primaryPort": 0,
"numMotorDrivers": 0,
"motorDrivers": [
"t": "None",
"s": "",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"invertEndstop": "0",
"minEndstop": "1",
"endstopPullup": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 999999,
"zHomeYPos": 999999,
"zHomeHeatHeight": 20,
"zHomeHeatAll": "1",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"zProbeDelay": 0,
"uiBedCoating": "1",
"langEN": "1",
"langDE": "1",
"langNL": "1",
"langPT": "0",
"langIT": "0",
"langES": "0",
"langFI": "0",
"langSE": "0",
"langFR": "0",
"langCZ": "0",
"langPL": "0",
"langTR": "0",
"langRU": "0",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"laserWarmupTime": 0,
"defaultPrinterMode": 0,
"laserPwmMax": 255,
"laserWatt": 2,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"cncPwmMax": 255,
"cncRpmMax": 8000,
"cncSafeZ": 150,
"startupGCode": ";Home G28 G1 X0 Y-100 Z030 F5000 ;Prime the extruder G92 E0 G1 F200 E30 G92 E0",
"jsonOutput": "0",
"bedLevelingMethod": 0,
"bedCorrectionMethod": 0,
"bedLevelingGridSize": 5,
"bedLevelingRepetitions": 5,
"bedMotor1X": 0,
"bedMotor1Y": 0,
"bedMotor2X": 200,
"bedMotor2Y": 0,
"bedMotor3X": 100,
"bedMotor3Y": 200,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": -1,
"sharedExtruderHeater": "0",
"extruderSwitchXYSpeed": 100,
"dualXAxis": "0",
"boardFanSpeed": 255,
"keepAliveInterval": 2000,
"moveXWhenHomed": "0",
"moveYWhenHomed": "0",
"moveZWhenHomed": "0",
"preheatTime": 30000,
"multiZEndstopHoming": "0",
"z2MinMaxPin": -1,
"z2MinMaxEndstop": 0,
"extruderIsZProbe": "0",
"boardFanMinSpeed": 0,
"doorPin": -1,
"doorEndstop": 0,
"zhomePreRaise": 0,
"zhomePreRaiseDistance": 10,
"dualXResolution": "0",
"x2axisStepsPerMM": 100,
"coolerPWMSpeed": 0,
"maxFanPWM": 255,
"raiseZOnToolchange": 0,
"distortionLimitTo": 2,
"automaticPowerup": 0,
"hasTMC2130": "0",
"TMC2130Sensorless": "0",
"TMC2130Steathchop": "1",
"TMC2130Interpolate256": "1",
"TMC2130PWMAmpl": 255,
"TMC2130PWMGrad": 1,
"TMC2130PWMAutoscale": "1",
"TMC2130PWMFreq": 2,
"TMC2130CSX": -1,
"TMC2130CSY": -1,
"TMC2130CSZ": -1,
"TMC2130CSE0": -1,
"TMC2130CSE1": -1,
"TMC2130CSE2": -1,
"TMC2130CSE3": -1,
"TMC2130CSE4": -1,
"TMC2130CurrentX": 1000,
"TMC2130CurrentY": 1000,
"TMC2130CurrentZ": 1000,
"TMC2130CurrentE0": 1000,
"TMC2130CurrentE1": 1000,
"TMC2130CurrentE2": 1000,
"TMC2130CurrentE3": 1000,
"TMC2130CurrentE4": 1000,
"microstepX": 16,
"microstepY": 16,
"microstepZ": 16,
"microstepE0": 16,
"microstepE1": 16,
"microstepE2": 16,
"microstepE3": 16,
"microstepE4": 16,
"parkPosX": 0,
"parkPosY": 0,
"parkPosZ": 10,
"emergencyParser": -1,
"hostRescue": "1",
"MAX31855SwCS": -1,
"MAX31855SwCLK": -1,
"tempGain": "1",
"hasMAX6675": false,
"hasMAX31855": false,
"hasMAX31855SW": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 100.4,
"primaryPortName": ""
  • That sounds strange. I guess connecting resets board which is ok and intentional, but would disable bed if it was on.
    None the less it should be no problem to enable it again in server. You should open console and enable Commands and ack and disable filter M105. Reset printer and check console. Enavle heater in server and check console. You should see temperature response having set temperture or you should have gotton an error message why heaters are disabled.
    Set temperture 0 means disbled so after connect that would be ok, but not when you activate heating.
  • How can  I enable heater in server? I can only find the max temp settings for the bed, no enable button.
  • I opend the console and set the buttons you suggested, below is the outcome. I did some more testing, and found that if I reset the Eprom with the button on the printer the bed temp reading comes back, even with the server active. If I reset with the USB disconected I get the values, then when I plug in they are gone. So every time the printer reboots the bed temp is disabled, and after a reset off the Eprom they're back.
    Does this make sense?
    Mesg:14:03:01.042: Connection closed by os.
    Mesg:14:03:08.185: Connection started
    Mesg:14:03:08.185: Printer reset requested false
    Mesg:14:03:08.186: Dtr: false Rts: false
    Mesg:14:03:08.222: Dtr: true Rts: true
    Recv:14:03:09.134: Connection verified by:start
    Recv:14:03:09.134: Printer reset detected:start
    Recv:14:03:09.134: start
    Send:14:03:09.134: N0 M110 N0
    Send:14:03:09.134: N1 M999 ; In case we did not reset recover from fatal state
    Send:14:03:09.134: N3 M115 ; Check firmware and capabilities
    Send:14:03:09.134: N4 M220 S100 ; set speed multiplier
    Send:14:03:09.135: N5 M221 S100 ; set flow multiplier
    Send:14:03:09.135: N6 M355 ; get light status
    Send:14:03:09.135: N7 G92 E0 ; reset extruder position
    Send:14:03:09.135: N8 G90 ; absolute coordinates
    Send:14:03:09.135: N9 M82 ; absolute E values
    Send:14:03:09.135: N10 G21 ; units are mm
    Send:14:03:09.135: N11 M114 ; check position
    Send:14:03:09.135: N12 M111 S6 ; debug flags
    Send:14:03:09.135: N13 M360 ; get configuration
    Send:14:03:09.135: N14 M539 S1
    Send:14:03:09.135: @getip
    Recv:14:03:09.157: Info:PowerUp
    Recv:14:03:09.157: Info:External Reset
    Recv:14:03:09.157: Info:Brown out Reset
    Recv:14:03:09.157: Detected EEPROM version:20
    Recv:14:03:09.157: Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    Recv:14:03:09.157: XY jerk was too low, setting to 12.61
    Send:14:03:09.157: N15 M117 192.168.1.94:3344
    Recv:14:03:10.420: zDistortionCorrection:0
    Recv:14:03:10.420: Free RAM:1307
    Recv:14:03:10.666: Card successfully initialized.
    Recv:14:03:10.686: Autoretract:0
    Recv:14:03:10.686: X:0.00 Y:0.00 Z:0.000 E:0.0000
    Recv:14:03:10.690: SelectExtruder:0
    Recv:14:03:10.691: FlowMultiply:100
    Recv:14:03:10.691: ok
    Recv:14:03:10.699: ok 1
    Recv:14:03:10.703: DebugLevel:6
    Mesg:14:03:10.703: info:Continue from fatal state
    Recv:14:03:10.703: ok
    Recv:14:03:10.703: ok 1
    Recv:14:03:10.707: ok 2
    Recv:14:03:10.711: ok 3
    Recv:14:03:10.728: FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Apr 9 2023 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    Recv:14:03:10.728: Cap:PROGRESS:1
    Recv:14:03:10.732: Cap:AUTOREPORT_TEMP:1
    Recv:14:03:10.732: Cap:HOST_RESCUE:1
    Recv:14:03:10.732: Cap:EEPROM:1
    Send:14:03:10.732: N17 M155 S1
    Send:14:03:10.732: N18 M415
    Recv:14:03:10.736: Cap:AUTOLEVEL:1
    Recv:14:03:10.736: Cap:Z_PROBE:1
    Recv:14:03:10.736: Cap:SOFTWARE_POWER:0
    Recv:14:03:10.740: Cap:TOGGLE_LIGHTS:1
    Recv:14:03:10.740: Cap:PAUSESTOP:1
    Recv:14:03:10.744: Cap:PREHEAT:1
    Recv:14:03:10.744: Cap:EMERGENCY_PARSER:0
    Recv:14:03:10.748: Printed filament:60.00m Printing time:0 days 0 hours 3 min
    Recv:14:03:10.752: PrinterMode:FFF
    Recv:14:03:10.752: ok 4
    Recv:14:03:10.752: SpeedMultiply:100
    Recv:14:03:10.752: ok 5
    Recv:14:03:10.756: FlowMultiply:100
    Recv:14:03:10.756: ok 6
    Recv:14:03:10.756: Info:Case lights on
    Recv:14:03:10.756: ok 7
    Recv:14:03:10.756: ok 8
    Recv:14:03:10.760: ok 9
    Recv:14:03:10.760: ok 10
    Recv:14:03:10.760: ok 11
    Recv:14:03:10.764: X:0.00 Y:0.00 Z:0.000 E:0.0000
    Recv:14:03:10.764: Error:Wrong checksum
    Recv:14:03:10.764: Resend:12
    Recv:14:03:10.777: Ignore due to resend: ok
    Recv:14:03:10.792: Waiting for resend requests finished. Starting resends ...
    Send:14:03:10.792: Resend: N12 M111 S6 ; debug flags
    Recv:14:03:10.797: ok 12
    Recv:14:03:10.797: DebugLevel:6
    Send:14:03:10.797: Resend: N13 M360 ; get configuration
    Recv:14:03:10.801: ok 13
    Send:14:03:10.801: Resend: N14 M539 S1
    Recv:14:03:10.806: Config:Baudrate:115200
    Recv:14:03:10.806: Config:InputBuffer:127
    Recv:14:03:10.810: Config:NumExtruder:1
    Recv:14:03:10.810: Config:MixingExtruder:0
    Recv:14:03:10.810: Config:HeatedBed:1
    Recv:14:03:10.814: Config:SDCard:1
    Recv:14:03:10.814: Config:Fan:1
    Recv:14:03:10.814: Config:Fan2:0
    Recv:14:03:10.818: Config:LCD:1
    Recv:14:03:10.818: Config:SoftwarePowerSwitch:0
    Recv:14:03:10.822: Config:XHomeDir:-1
    Recv:14:03:10.822: Config:YHomeDir:-1
    Recv:14:03:10.826: Config:ZHomeDir:1
    Recv:14:03:10.826: Config:XHomePos:0.00
    Recv:14:03:10.826: Config:YHomePos:0.00
    Recv:14:03:10.830: Config:ZHomePos:448.000
    Recv:14:03:10.830: Config:SupportG10G11:1
    Recv:14:03:10.834: Config:SupportLocalFilamentchange:1
    Recv:14:03:10.838: Config:CaseLights:1
    Recv:14:03:10.838: Config:ZProbe:1
    Recv:14:03:10.838: Config:Autolevel:1
    Recv:14:03:10.842: Config:EEPROM:1
    Recv:14:03:10.842: Config:PrintlineCache:16
    Recv:14:03:10.846: Config:JerkXY:12.61
    Recv:14:03:10.847: Config:KeepAliveInterval:2000
    Recv:14:03:10.851: Config:RetractionLength:3.00
    Recv:14:03:10.855: Config:RetractionLongLength:13.00
    Recv:14:03:10.855: Config:RetractionSpeed:40.00
    Recv:14:03:10.859: Config:RetractionZLift:0.00
    Recv:14:03:10.863: Config:RetractionUndoExtraLength:0.00
    Recv:14:03:10.867: Config:RetractionUndoExtraLongLength:0.00
    Recv:14:03:10.867: Config:RetractionUndoSpeed:20.00
    Recv:14:03:10.871: Config:XMin:0.00
    Recv:14:03:10.871: Config:YMin:0.00
    Recv:14:03:10.875: Config:ZMin:0.00
    Recv:14:03:10.875: Config:XMax:200.00
    Recv:14:03:10.875: Config:YMax:200.00
    Recv:14:03:10.879: Config:ZMax:448.00
    Recv:14:03:10.879: Config:XSize:200.00
    Recv:14:03:10.883: Config:YSize:200.00
    Recv:14:03:10.883: Config:ZSize:448.00
    Recv:14:03:10.887: Config:XPrintAccel:1000.00
    Recv:14:03:10.888: Config:YPrintAccel:1000.00
    Recv:14:03:10.892: Config:ZPrintAccel:1000.00
    Recv:14:03:10.892: Config:XTravelAccel:1000.00
    Recv:14:03:10.896: Config:YTravelAccel:1000.00
    Recv:14:03:10.900: Config:ZTravelAccel:1000.00
    Recv:14:03:10.900: Config:PrinterType:Delta
    Recv:14:03:10.904: Config:MaxBedTemp:120
    Recv:14:03:10.904: Config:Extr.1:Jerk:20.00
    Recv:14:03:10.908: Config:Extr.1:MaxSpeed:50.00
    Recv:14:03:10.912: Config:Extr.1:Acceleration:5000.00
    Recv:14:03:10.912: Config:Extr.1:Diameter:0.00
    Recv:14:03:10.917: Config:Extr.1:MaxTemp:310
    Recv:14:03:10.917: ok 14
    Send:14:03:10.917: Resend: N15 M117 192.168.1.94:3344
    Recv:14:03:10.924: ok 15
    Recv:14:03:10.932: ok 16
    Send:14:03:10.932: Resend: N17 M155 S1
    Recv:14:03:10.937: ok 17
    Send:14:03:10.937: Resend: N18 M415
    Recv:14:03:10.941: ok 18
    Recv:14:03:10.941: RESCUE_STATE: OFF
    Recv:14:03:22.956: wait (12)
    Send:14:03:23.232: @getip
    Send:14:03:23.250: N19 M117 192.168.1.94:3344
    Recv:14:03:23.256: ok 19
    Recv:14:05:50.443: wait (147)
    Send:14:05:51.342: N20 M20
    Send:14:05:51.342: N21 M115
    Recv:14:05:51.344: ok 20
    Recv:14:05:51.348: Begin file list
    Recv:14:05:51.360: prints/
    Recv:14:05:51.365: prints/dime - PLA.gcode 141184
    Recv:14:05:51.369: prints/dime pet.gcode 141184
    Recv:14:05:51.373: prints/Fan2.6f.gcode 25708064
    Recv:14:05:51.373: prints/Filament rings.gcode 533533
    Recv:14:05:51.377: prints/Hinges-a.gcode 1821427
    Recv:14:05:51.381: prints/3DBenchy.gcode 3302888
    Recv:14:05:51.381: prints/Fan half size.gcode 12762863
    Recv:14:05:51.385: prints/dime.gcode 133154
    Recv:14:05:51.385: Hinges -b V2.stl 74484
    Recv:14:05:51.389: Hinges-b-V2.gcode 688285
    Recv:14:05:51.393: Bin handle wide.gcode 631998
    Recv:14:05:51.393: Bin handle big.gcode 1372703
    Recv:14:05:51.398: BitBox.gcode 190727
    Recv:14:05:51.402: Heat_tower_190-240_Bridge.gcode 1452921
    Recv:14:05:51.402: TempTower PETG2.gcode 1556716
    Recv:14:05:51.405: Heat_tower PetG 260 - 220.gcode 1255269
    Recv:14:05:51.410: Clamp printhead.gcode 3256672
    Recv:14:05:51.410: BitBoxv3.1.gcode 1461063
    Recv:14:05:51.414: End file list
    Recv:14:05:51.414: ok 21
    Recv:14:05:51.430: FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Apr 9 2023 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    Recv:14:05:51.430: Cap:PROGRESS:1
    Recv:14:05:51.430: Cap:AUTOREPORT_TEMP:1
    Send:14:05:51.430: N22 M155 S1
    Recv:14:05:51.434: Cap:HOST_RESCUE:1
    Recv:14:05:51.434: Cap:EEPROM:1
    Recv:14:05:51.434: Cap:AUTOLEVEL:1
    Send:14:05:51.435: N23 M415
    Recv:14:05:51.439: Cap:Z_PROBE:1
    Recv:14:05:51.439: Cap:SOFTWARE_POWER:0
    Recv:14:05:51.443: Cap:TOGGLE_LIGHTS:1
    Recv:14:05:51.443: Cap:PAUSESTOP:1
    Recv:14:05:51.443: Cap:PREHEAT:1
    Recv:14:05:51.447: Cap:EMERGENCY_PARSER:0
    Recv:14:05:51.452: Printed filament:60.00m Printing time:0 days 0 hours 3 min
    Recv:14:05:51.452: PrinterMode:FFF
    Recv:14:05:51.455: ok 22
    Recv:14:05:51.455: ok 23
    Recv:14:05:51.455: RESCUE_STATE: OFF
    Send:14:05:51.574: N24 M155 S1
    Recv:14:05:51.577: ok 24
    Recv:14:06:17.612: wait (26)
  • b.t.w. I didn't find an enable button for the bed, but did find a temp setting in the console, to witch the printer responds
  • Enabling bed is done by sending the temperature. If that works all is ok. As I said on connect it resets printer and disables temperatures.
    In console output you still had M105 filter on so no temperatures appear there. Also it should cover a time from where you set a bed temperature, but I guess from what you write all is ok, you just expected the temperature to stay when connecting.
  • I retried, now with the filter of. below the values.
    The printer only works fine after I reset the Eprom, this has to be done after every reset of the board. without a reset I can set the values in the console, but they have no effect. Also in the host the entire bed temp setting is gone.
    In this part the readings where I reset the Eprom:
    Recv:9:06:54.963: wait
    Recv:9:06:55.353: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:06:55.963: wait
    Recv:9:06:56.454: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:06:56.967: wait
    Recv:9:06:57.553: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:06:57.967: wait
    Recv:9:06:58.651: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:06:58.970: wait
    Recv:9:06:59.749: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:06:59.969: wait
    Recv:9:07:00.846: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:00.970: wait
    Recv:9:07:01.944: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:02.973: wait (2)
    Recv:9:07:03.042: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:03.976: wait
    Recv:9:07:04.144: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:04.975: wait
    Recv:9:07:05.242: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:05.980: wait
    Recv:9:07:06.340: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:06.979: wait
    Recv:9:07:07.439: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:07.979: wait
    Recv:9:07:08.536: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:08.982: wait
    Recv:9:07:09.634: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:09.982: wait
    Recv:9:07:10.732: T:12.56 /0 B:NAN /0 B@:0 @:0
    Recv:9:07:10.981: wait
    Recv:9:07:12.547: SelectExtruder:0
    Recv:9:07:12.547: FlowMultiply:100
    Recv:9:07:12.551: Info:Configuration reset to defaults.
    Recv:9:07:13.420: wait
    Recv:9:07:13.424: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:14.424: wait
    Recv:9:07:14.427: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:15.422: wait
    Recv:9:07:15.529: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:16.426: wait
    Recv:9:07:16.627: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:17.426: wait
    Recv:9:07:17.725: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:18.430: wait
    Recv:9:07:18.823: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:19.429: wait
    Recv:9:07:19.921: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:20.429: wait
    Recv:9:07:21.019: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:21.432: wait
    Recv:9:07:22.117: T:12.56 /0 B:12.56 /0 B@:0 @:0
    Recv:9:07:22.431: wait
    Recv:9:07:23.219: T:12.56 /0 B:12.56 /0 B@:0 @:0
    In this part the readings where I change the temp through the console:
    Recv:9:54:45.460: T:13.80 /0 B:NAN /0 B@:0 @:0
    Recv:9:54:45.874: wait
    Recv:9:54:46.560: T:13.80 /0 B:NAN /0 B@:0 @:0
    Recv:9:54:46.878: wait
    Recv:9:54:47.656: T:13.80 /0 B:NAN /0 B@:0 @:0
    Recv:9:54:47.877: wait
    Recv:9:54:48.754: T:13.49 /0 B:NAN /0 B@:0 @:0
    Recv:9:54:48.877: wait
    Recv:9:54:49.853: T:13.80 /0 B:NAN /0 B@:0 @:0
    Recv:9:54:50.880: wait (2)
    Recv:9:54:50.950: T:13.80 /0 B:NAN /0 B@:0 @:0
    Send:9:54:51.700: N22 M140 S38 H0
    Recv:9:54:51.703: ok 22
    Recv:9:54:51.707: TargetBed:38
    Recv:9:54:52.052: T:13.80 /0 B:NAN /38 B@:0 @:0
    Recv:9:54:52.708: wait
    Recv:9:54:53.150: T:13.80 /0 B:NAN /38 B@:0 @:0
    Recv:9:54:53.707: wait
    Recv:9:54:54.248: T:13.80 /0 B:NAN /38 B@:0 @:0
    Recv:9:54:54.712: wait
    Recv:9:54:55.346: T:13.80 /0 B:NAN /38 B@:0 @:0
    Recv:9:54:55.710: wait
    Recv:9:54:56.444: T:13.80 /0 B:NAN /38 B@:0 @:0
    Recv:9:54:56.710: wait
    Recv:9:54:57.541: T:13.80 /0 B:NAN /38 B@:0 @:0
    So it seems somehow the default settings aren't loaded after a reset
  • I found out that if I send a M502 through the host, the printer displays the temp of the bed again. I added M502 to the startup_gcode in the firmware but this doesn't work. It seems like the eeprom values arent read, max jerk for example stays on 0, while it is set to 20 in the firmware. When I turn the EEprom of in firmware all temp values are displayed on the display, even after a reset.
    I also cleared the eeprom with a little arduino sketch, but this also didn't help. same with restoring the eeprom with the values i downloaded from the original firmware.
  • Or sounds like one of the PID variables in eeprom is not a correct value and M502 replaces it with good ones. Did you also send M500 afterwards to store new values to eeprom?
    Strange part is
    The measured temperature does not depend on PID it soley depends on sensor and pin which are both not saved in eeprom. Only way to change it afterwardsa is with TEMP_GAIN enabled and one of the values for gain is invalid.
  • I did send a M500 behind the M502, but this has no effect. It could be the pid values are wrong, I never changed them from the website. I figured the were default and I'll fine tune later. Values were P196, I 33 and D was 92.
    Today I tried to remove the pid controler for the bed, and set the firmware to dead time control, but tis gives the same result
  • Just checked and you have
    #define TEMP_GAIN 1
    Set it to 0 and increase EEPROM_MODE to force initalizing eeprom with new values. That should get rid of the bad value causing the NaN.
    PID values for I is quite big it is normally more like 0.3 but you can run M303 for the extruder to find out good values.
  • I turned the Temp_Gain off, and on again, and Off again. And this indeed was the problem. When the gain is on the temp of the bed doesn't work
  • Gain on would work but there is apparently a invalid number in the eeprom place of it. But normally it is not needed so leaving it off is ok. Had recently done somthing with it so maybe you would need 1.0.5dev to have it working correctly.
