Manual control X/Y erratic behaviour
Hi
I just found the following erratic behaviour on the manual X/Y control (on Raspberry PI gui w/ Renkforce RF1000)
I've homed all axes. For this example, I've set 10mm (happens on different values also)
- X position is 0
- I press "right"
- Extruder moves 10mm right
- I press "right"
- Extruder moves 20mm right
- I press "right"
- Extruder moves 30mm right (while X value on screen is now 30, Extrudes has moved 50mm)
- I press "left"
- Extruder moves 20mm right (shown X now 20, Extruder position now 70mm)
- I press "left"
- Extruder moves 10mm right (shown X now 10, Extruder position now 80mm)
- I press "left"
- Extruder doesn't move (shown X now 0, Extruder position still 80mm)
- I press "left"
- Extruder moves 10mm left (shown X remains 0, Extruder position now 70mm)
- I press "left"
- Extruder moves 10mm left (shown X remains 0, Extruder position now 60mm)
Continuing pressing X left acts normal, extruder moves always 10mm.
Pressing X right again and things start over.
Same behaviour on Y axis, while Z axis seem to operate normal
Regards
Holger
  • Firmware should start up in absolute positioning mode. Looks like yours is operating in relative mode.
  • Ah, that might be an explaination while I've never noticed this issue before (after I had a jub run), I've G90 in my start G-Code. Will doublecheck tomorrow and report back.
  • Guess here is my confirmation pending. Agreed, G90 will solve this issue. I don't know why this RF1000 fork starts up in relative mode.
