Number of prints
Am I missing something or is the number of prints a feature of the gcode files and not the projects?
  • Yes if you print a file we check if same file exists in gcode models and we increase it. We do not check all project repositories with all projects to find if one has also a gcod ewith same filename.
    Fact is there is no connectioan between any of these files. It might also just a direct print uploaded only to print queue. We do not know where a gcode came from.
  • Repetier server is fantastic: I've been testing it and it's really reliable.
    The cost of the pro license is nothing compared to its features.
    Too bad you can't count the number of completed prints of each file.
    Can't add this feature? I also need to know the number of prints.
  • Not for projects. Files could be renamed, have multiple copies or be on a server currently not running. So there is no safe way to do that since we always make copies to not need the original.
    Thank you for answering me.
    Then I'll use the gcode file groups of the printers.
